Hi Greg, Thanks for the replies.
The saving to a removable drive issue I did find the arrow change to the hard drive. I think it's a bit pointless to have a feature that doesn't do as most ofther programs do when there is a duplicate file and ask to replace it or overwrite it.
The first post was on thread from 2020. I thought I inclued a photo of the finshed print, gcode and 3mf file.
The Geetech A10M was the same price ($275 AU) or less than some of the single extruder machines at that time.
The 2 in 1 extruder doesn't need a standby tempreature it can keep running, in the past I have edited the gcode and inserted T0 and T1 at predetermined layer heights. I have done the same with tempreatures with wood pla.
What I am going to do now is swop the filiment over so T0 does the first part then T1 for the second see how that goes.
GA_12_Lucida Handwriting-1.5Z.gcode GA_12_Lucida Handwriting-1.5Z.3mf
Slashee_the_Cow 27
There should be an arrow button next to "Save to Removable Drive", which brings up a list of currently connected removable drives or just the regular "Save to Disk" option.
I did already respond in the other topic you posted in, which you should at the very least have provided a link to (especially since it has a download of the gcode), I'm not sure how much @gr5 likes someone posting a duplicate just because they don't get a solution in under four hours.
As I said there, I don't have a printer with two extruders, and I didn't even know you could get printers with two extruders but a single hot end (mostly because I've never looked at dual extruder printers because they're out of my price range) so I have no idea how well Cura handles that. Someone who knows more than me (maybe @GregValiant) will have to step in on that one.
