- Solution
If you use tree supports, they should be created outside of the model and only branch up to the overhang where needed.
1
Thank you all for help! Reducing support horizontal expansion to 0 seemed to fix the issue. What intrigues me is that cura will show where supports will be generated with red areas, but with support horizontal expansion those areas that are not shaded red will still generate supports.
I think the lower support was in some strange way supposed to support the upper support. If they weren't right above each other I think there would have been zero support in the lower area. If that makes some kind of weird sense.
Torgeir 248
Hi @Skas.
Welcome in here.
My best advice, stay away from Cura 5.40, this advice cause this version of Cura have some nasty issues..
If you just need to use the later version of Cura due to the line width control -then use version 5.2.2 as this version handle support very well.
Thanks
Torgeir
