Setting the skirt height back to 1 for each new print is no longer necessary when switching to cura 5.3 or 4.13 for the time being 🙂
but it's standard settings like this, which i have to adjust with every new print, that make using cura unnecessarily inconvenient in the meantime.
GregValiant 1,271
I have a couple of overrides in my definition file. One more didn't take but a second.
"skirt_height": { "default_value": 1 }
Wait, am I the only one here who saves their own custom quality presets?
GregValiant 1,271
That doesn't work for me. I end up changing them for every print anyway.
I have "Slow PLA", "Fast PLA", and "PETG" and I have a separate Ender 3 Pro installed for TPU because it needs it's own startup gcode.
So every print is a custom setup.
Slashee_the_Cow 295
By this point it's very well known that Cura 5.4 has some bugs, especially when it comes to slicing. Something you can do try and mitigate the problem is go to Mesh Fixes > Maximum Resolution. 0.5mm is a good starting point, if that doesn't work try going down a bit at a time.
GregValiant 1,271
The "Skirt Stacking" is a new setting in 5.4.0. I've never had a problem removing the skirt from the bed so I don't need that setting at all. The setting is in the Bed Adhesion section, it's called "Skirt Height" and the default is "3" layers high.
Set it to "1" and you will be back to having the skirts as you expect.
LePaul 323
Adding addition layers of Skirt Height in 5.4 is the most moronic change I've seen with Cura. And I've been here since 2014!
