yes the fan is going
Ultimaker s5 with 0.4mm CC nozzle stops extruding nylon 6 CF filament after a few hours of printing
- 3 weeks later...
Do you happen to have something specific at this 4 hours threshold ? Maybe some fast contours for instance ?
You might be close to the max flow rate allowed for that given material, and UMS5 is really really bad at flow rate extrusion. If it always happen at a given spot of your print, it's maybe because of a geometry that is eager to go faster / wider / thicker layer.
You say "I get an under-extrusion error of about 0.3 units under the minimum threshold" : I don't get it, what is this "0.3 units" ? Do you have some kind of feedback I don't have, when it comes to UnderExtrusion sensor error ? Maybe it's in the LOG file ?
I really really often face this under extrusion sensor trigger... Be it with PVA on BBCore, or PETG / PLAtough on AACore, when I print "fast".
You might want to try turning the maximum amount of retractions down, or even try turning retractions off completely just to test.
When and how the feeders grind into material can feel a bit random sometimes - but I've found that it helps with materials where the feeders really like to dig into it (mostly TPU on my end).
The moment that the feeders dig into filament enough will also be the moment that your printer will start showing you the flow rate error.
Hi @madest,
Printing with this type of filament means we are in "experimental" mode. Nylon with 20% added chopped carbon fiber is one of the strongest filaments we can find. Normal print temperatures are: 280 deg C., - to max - 300 deg C. As you say you print with the highest possible temperature, how high a temperature do you use? In your case, you should take a closer look at the cooling fan in the front, which should cool both sides. Like @gr5 said, the cooling fan must be working and in your case it's very important. Also make sure that there is no collected filament "strings" in the inlet side of the fan.
All of what you're describing pointing to the cooling of the upper part of the nozzle.
Are you using any support filament during this printing?
If not, you might be able to improve the air flow "a little" to core no 1..
Thanks
Torgeir.
gr5 2,176
Is the front fan working? The symptoms you describe sound like what happens when the front fan is not spinning. Not the side fans on the print head - the fan in the door of the print head.
