GregValiant 1,330
@tstage Check the cable management for the bed and print head. If the cable hangs up on something then you can get belt slippage (a chattering noise) and so the stepper motor loses it's position causing a layer shift.
The problem is more prevalent with the Y axis, but check them all anyway and make sure there is no binding and everything is free to move back and forth.
Check the belt tension as well.
Reddit has a large Ender 3 user group and you should be able to find support there.
Dustin 150
Hi there,
This is the UltiMaker community.. While there is UltiMaker Cura users here with 3rd party 3d printers as well..
You appear to be having hardware issues with your machine, you would get better help reaching to Creality or their users communities.
