8 hours ago, GregValiant said:I agree, the gcode looks to be correct both in the Cura preview and in the PrusaSlicer Gcode viewer.
That pretty much just leaves either the SD card (bad memory sector and part of the gcode was in the bad sector) or the printer itself.
The under-extrusion is troublesome and needs to be addressed.
I can't really address it since nothing else produces these results. I actually re-made the g-code with the same model and the same settings, also thinking it might be some file corruption, but no. The ironing broke in the exact same way, only covering 1/3rd of the model and stopped in the exact same spot. I can't blame the printer for it, since if the printer clogged or something, the results wouldn't be uniform
GregValiant 1,330
