Dim3nsioneer 556
Okay, so I've got a couple thoughts for you Daid that I think would greatly improve some prints for Cura 14.4.
First, a comb vs. retract variable would be awesome. I.E., I don't mind if it wants to comb on an infill around the steeply angled portion of a circle where it would be combing less than 10 mm, but I don't want it to comb all the way across the 200 mm part. That should be a fairly easy one I think, just comparing the two values and generating the appropriate move based upon the user variable (probably in the expert settings so the newbies don't accidentally mess things up).
I agree completely about the combing vs. retraction threshold. I've had way too many prints structurally ruined due to long combing moves that cause massive underextrusion after dropping all of their plastic during the comb.
I don't even think it necessarily needs to be a user-facing variable - just set it so that all moves longer than 10mm or so require a retraction. I think there is probably a sweet spot around 10mm which is the correct value in almost all circumstances
Guys, for the case you don't know the plugin: RetractWhileCombing might give you what you want when filled with the right numbers...
nick-foley 5
