Mobility survey for Ultimaker
SandervG
Posted · Mobility survey for Ultimaker
Hi All,
Rutger from our R&D department took the time to write down a small survey for our users. With our community being all responsive and involved and all I figured it wouldn't be much of a problem to ask a couple of minutes from your time to fill out this survey. :)
It is about the mobility of Ultimaker Original / Ultimaker 2.
Is it always at the same place, or moved around a lot and on what areas can it be improved. etc
It would be much appreciated if you could spare 3-4 minutes to fill it out.
The Survey can be found http://tinyurl.com/UltimakerSurvey.
Thanks and have a great day!
- Sander.
    Filled out. :-P
    I had to fill out all questions, also those which were actually not applicable.
    btw: the UM transporter drone would have been sooooo cooooool....! :cool:
    Done ... :-P
    Somehow rather strange questions. :???:
    But more importantly, what is there for the participants to win? :mrgreen:
    For me, please, an air-cushion boat. :mrgreen: :mrgreen: :mrgreen:
    Markus
    Done too... :-)
    Thanks guys! :) Much appreciated!
    Done mine too. You should have the ultimaker forum contribute to the design... give us the brief :) We can help.
    Hi Sander
    Have you closed the survey?
    The form "Ultimaker mobility survey " is no longer accepting responses. Try contacting the owner of the form if you think this is a mistake.
    Looks like the survey is finished
