I'm not convinced this part really needs support in that print orientation. If I did want support, I'd add something custom using meshmixer to just support the very top parts of the overhangs.
Hi. Thanks for tips. I assume file is for rough surface and wet sandpaper for small detail/polishing.
Meshmixer look really intresting. I need to take better look on it later.
Sometimes I use a regular lighter to get rid of the 'white-ish' looking parts were the support material used to adhere to the model. Just a second in the flame works well.
- 3 weeks later...
This looks like is going to break, I would have printed it in a different orientation
yellowshark 153
If filing then some baby oil will bring back the lustre to the filament
IRobertI 513
A small file or some sand paper wrapped around my finger. Wetsand paper works quite nicely as the added water helps keep the plastic cool as you sand it.
