Guest
Yes, I have an Ultimaker 2. Do you mean the screw on top of the extruder? It was loose and on the top position.
Currently pritning without retraction to see if it doesn't get more pressed. Two pictures included below if they make any sense.
Thanks, Axel
IRobertI 513
I'm assuming you have a UM2? If so, there's an adjustment screw to the right of the bowden on the feeder. When the little white dial indicator is at the top is when there's the least amount of pressure on the filament.
If you have a UM-Original you can unscrew the screw that holds the spring in place on the arm of the feeder.
