Ultimaker 2 firmware upgrade not recognised
Posted · Ultimaker 2 firmware upgrade not recognised
Hi, i would like to upgrade to the last firmware (cura 14.03) of my ultimaker 2..but when i attach it to the usb port of my computer it does not recognise the board.. (the ultimaker)..
i tried even with the laptop but is the same..
what i can do?
I always get unknown device.
    Is there a way to download the ultimaker 2 driver directly??
    I tried everything but nothing seems to work. I extracted the driver folder from cura but seems that the drivers inside doesn't work either..
    Ok... I am lost.
    Each time we upgrade Cura must be load a new firmware to the printer?
    Not always. But one in a while the firmware of the ultimaker (in this case the ultimaker 2) is upgraded and you should do it. Since the release the Ultimaker had 2 firmware upgrade. This is the second... and i don't know why i can't do it! My computer (3 computers) does not recognise anymore the ultimaker 2.
    So i still have the former firmware.
    Did you try a different cable? There's more help on the arduino webistes but here's how to debug USB issues...
    usb debugging (post #7):
    http://umforum.ultimaker.com/index.php?/topic/5100-how-to-update-um2-firmware/?p=46156
    Yeah! Incredible but was the cable! I updated the ultimaker finally!
    I see however that the led brightness problem is still there..
