"Feel free to build it"
C'mon daid, no need to get snarky. It was just a suggestion.
As a workaround for tony I would suggest giving Repetier Host a try to view the generated Gcode. It's a bit of a pain to move between two different programs but you will be able to view the layers in full, in sections or a layer at a time. Personally the thing I miss most in cura is a true top down, non perspective view of single layers at a time.
Daid 301
Feel free to build it. As I'm spending my time on other things right now.
Note that the 14.03 update cause the layerview to work a lot better for mid to low end PCs, and I get a lot of happy reactions because of it.
And infills are not hidden in the lower layers, they are yellow outlined.
