Dim3nsioneer 559
I agree on making the frame heavier would be a good thing. But my present approach is rather to decouple vibrations from the frame as far as possible.
However, I think it's not possible to get the z stage to vibrate/oscillate in phase with the frame as the two systems are coupled with springs; not only the four springs below the building platform but also the whole wooden construction of the stage which can oscillate.
anon4321 16
Bloody brilliant!!!!
Although, I would think that the opposite would be the way to go. The z-stage should always be the same distance from the from the print head in all three axes during printing when the head moves.
The movement of the head doesn't move the z-stage directly. Instead, the shifting of the frame is then translated into the z-stage. If the shifting of the z-stage doesn't exactly match that of the rest of the frame, the relative positioning of the stage to the head will have error.
I would think that the way to reduce this error is to make sure the z-stage stays in sync with the shifting of the frame.
There are two ways to do that. Make the z-stage LIGHTER or prevent the frame from shifting by making IT heavier and more rigid.
I guess I should read the other thread.
