I guess that you can't prime unless doing it by hand as well as i supose you only want to paint the numbers and use plastic only on the rest of the dice.
By the way, do you use brush or some kind of a marker.
If using a marker i think it can be hard as the paint is extreamly thin.
If using a brush and a little thicker paint i think the problem might be bad bonding between layers. Make sure thay you dont have under extrusion problems and if not, try to print a little hotter.
fingerpuk 0
Are you using a primer at all? I prime with two coats before adding paint, works a treat.
