Yes, it's a deliberate feature that I added recently - or at least fine tuned to where it works a bit better. (It actually used to try and purge as much or more, but did it so fast that most printers couldn't keep up - and that lead to stripping of the filament on some printers.)
It purges 50mm³ - a little over half of the contents of the print head - at a fast normal printing speed. The idea is to ensure the head is full of plastic, make up for any filament that might have leaked during heat up, and flush through most of the plastic that may have sat hot in the print head for a while.
I'm still open to ideas on how to make this work better. I think it should probably do it a bit closer to the bed, so the ejected plastic is more likely to stick to the bed (and/or the front left glass clip). And then maybe do a quick left to right pass on the front of the bed, almost touching, to try and wipe off the head before the print proper starts...
Any ideas or requests?
Titus 170
This is actually a very usefull feature in my opinion. It makes sure your hot end is actually full of molten filament before starting to print. It has happened to me multiple times that it started printing without plastic coming out because I just changed the fillament and it hadn't reached the hot end yet. The purge helps you to make sure there is material coming out![:)](//content.invisioncic.com/ultimake/emoticons/5a33abdf6d109_1f60acopy.png)
