Tried to left Ultimaker 2 for 10-20 minutes with 260 temperature, and then printed, nothing happened
ABS or PLA? This is dangerous. Don't go over 220C without printing for more than a minute and try not to ever go over 240C with PLA. High temperatures will turn PLA and ABS into a caramelized gunk that sticks to the inner surface of your nozzle and has to be burned out into ash to get it as good as new again.
Safe temperatures for PLA - 180C idle (not printing). 240C printing fast. 220C printing slow.
Dim3nsioneer 557
What do you mean with 'nothing happened' when using the atomic method? What did the tip of the filament look like?
Did you check the feeder? Is it grinding? If you loosen the Bowden tube at the feeder's end (the same way you do it during the atomic method at the print head's end...), heat the nozzle to something like 210°C and push manually some filament through, does it flow continously?
