Chocolate printing
zoev89
Posted · Chocolate printing
Hi All,
In light of the recent ultimaker event I create this topic so we can combine our experiences with chocolate printing. My current status is that I have not yet printed chocolate but am in the process of preparing.
It started with printing the parts which can be found here
https://www.youmagine.com/designs/ultimaker-syringe-extruder-ii
Since I have a 60ml syringe (100ml is hard to get) I printed the middel file. Actually I updated the sketchup file to repair the bottom part so it can print without repairing the bottom in Cura. In this case you will have clean holes through the bottom layer.
You only need 3 parts all the other parts are not needed or do not fit the current ultimakers. The configuration looks like this:
Chocolate extruder
For testing Joris proposed to use some other paste then chocolate. I made some past from a mix of flower and heated water. Note before putting the paste in let it cool a bit since my syringe got smaller when hot so I could not put it together.
I have reused my bowdentube and used a small part for the syringe.
For the configuration to work you would need to pull the filament. Joris mentions that you need to replace the 'E' with 'E-' to get negative extrusion. I just set the flow to -100% and that does the trick. You need to change the start code and add
M302 ; run extruder when cold
and change
G1 F200 E3 ;extrude 3mm of feed stock
into
G1 F200 E-3 ;extrude 3mm of feed stock
My syringe has a diameter of 29mm so I set the filament diameter to 14.5 there is a factor 2 due to the way the filament is pulled.
If you generate your gcode you would need to remove the start of the gcode where it is heating up the nozzle and the bed. In my case remove the top part until you see the start code like this:
M140 S20.000000
M109 T0 S20.000000
T0
M190 S20.000000
;Sliced at: Mon 04-08-2014 10:18:24
;Basic settings: Layer height: 0.5 Walls: 2 Fill: 100
;Print time: #P_TIME#
To this:
The M and the T command are removed from the top.
I also added one of the spacers to operate the Z switch earlier and I just moved the syringe down so it touches the build plate when homed. Makes experimenting for a couple of runs easy.
I have been able to print some cylinders with my flower paste so far. I do notice that you quite quickly get filament grinding.
What are the experiences from the other people what were at the meeting. Did anybody experiment?
Here is my ini file
[profile]
layer_height = 0.5
wall_thickness = 2
retraction_enable = False
solid_layer_thickness = 0.4
fill_density = 100
nozzle_size = 2
print_speed = 20
print_temperature = 28
print_temperature2 = 0
print_temperature3 = 0
print_temperature4 = 0
print_bed_temperature = 24
support = None
platform_adhesion = None
support_dual_extrusion = Both
wipe_tower = False
wipe_tower_volume = 15
ooze_shield = False
filament_diameter = 14.5
filament_diameter2 = 0
filament_diameter3 = 0
filament_diameter4 = 0
filament_flow = -100.0
retraction_speed = 40.0
retraction_amount = 4.5
retraction_dual_amount = 16.5
retraction_min_travel = 1.5
retraction_combing = True
retraction_minimal_extrusion = 0.02
retraction_hop = 0.0
bottom_thickness = 0.3
layer0_width_factor = 100
object_sink = 0.0
overlap_dual = 0.15
travel_speed = 150.0
bottom_layer_speed = 20
infill_speed = 0.0
inset0_speed = 0.0
insetx_speed = 0.0
cool_min_layer_time = 5
fan_enabled = True
skirt_line_count = 1
skirt_gap = 5.0
skirt_minimal_length = 150.0
fan_full_height = 0.5
fan_speed = 100
fan_speed_max = 100
cool_min_feedrate = 10
cool_head_lift = False
solid_top = True
solid_bottom = True
fill_overlap = 15
support_type = Grid
support_angle = 60
support_fill_rate = 15
support_xy_distance = 0.7
support_z_distance = 0.15
spiralize = False
simple_mode = False
brim_line_count = 5
raft_margin = 5
raft_line_spacing = 1.0
raft_base_thickness = 0.3
raft_base_linewidth = 0.7
raft_interface_thickness = 0.2
raft_interface_linewidth = 0.2
raft_airgap = 0.22
raft_surface_layers = 2
fix_horrible_union_all_type_a = False
fix_horrible_union_all_type_b = False
fix_horrible_use_open_bits = False
fix_horrible_extensive_stitching = False
plugin_config = (lp1
(dp2
S'params'
p3
(dp4
sS'filename'
p5
S'TweakAtZ.py'
p6
sa.
object_center_x = -1
object_center_y = -1
[alterations]
start.gcode = ;Sliced at: {day} {date} {time}
;Basic settings: Layer height: {layer_height} Walls: {wall_thickness} Fill: {fill_density}
;Print time: {print_time}
;Filament used: {filament_amount}m {filament_weight}g
;Filament cost: {filament_cost}
;M190 S{print_bed_temperature} ;Uncomment to add your own bed temperature line
;M109 S{print_temperature} ;Uncomment to add your own temperature line
G21 ;metric values
G90 ;absolute positioning
M82 ;set extruder to absolute mode
M107 ;start with the fan off
G28 X0 Y0 ;move X/Y to min endstops
G28 Z0 ;move Z to min endstops
G1 Z15.0 F{travel_speed} ;move the platform down 15mm
G92 E0 ;zero the extruded length again
G1 F{travel_speed}
;Put printing message on LCD screen
M117 Printing...
end.gcode = ;End GCode
M104 S0 ;extruder heater off
M140 S0 ;heated bed heater off (if you have it)
G91 ;relative positioning
G1 E-1 F300 ;retract the filament a bit before lifting the nozzle, to release some of the pressure
G1 Z+0.5 E-5 X-20 Y-20 F{travel_speed} ;move Z up a bit and retract filament even more
G28 X0 Y0 ;move X/Y to min endstops, so the head is out of the way
M84 ;steppers off
start2.gcode = ;Sliced at: {day} {date} {time}
;M104 S{print_temperature} ;Uncomment to add your own temperature line
;M109 T1 S{print_temperature2} ;Uncomment to add your own temperature line
;M109 T0 S{print_temperature} ;Uncomment to add your own temperature line
G21 ;metric values
T1 ;Switch to the 2nd extruder
G1 F200 E10 ;extrude 10mm of feed stock
G1 F200 E-{retraction_dual_amount}
T0 ;Switch to the first extruder
G1 F{travel_speed}
M117 Printing...
end2.gcode = ;End GCode
M104 T0 S0 ;extruder heater off
M104 T1 S0 ;extruder heater off
M84 ;steppers off
start3.gcode = ;Sliced at: {day} {date} {time}
G21 ;metric values
T2 ;Switch to the 2nd extruder
G1 F{travel_speed}
M117 Printing...
end3.gcode = ;End GCode
M104 T2 S0 ;extruder heater off
M84 ;steppers off
;{profile_string}
start4.gcode = ;Sliced at: {day} {date} {time}
;M109 T2 S{print_temperature2} ;Uncomment to add your own temperature line
G21 ;metric values
T3 ;Switch to the 4th extruder
T2 ;Switch to the 3th extruder
G1 F{travel_speed}
M117 Printing...
end4.gcode = ;End GCode
M104 T3 S0 ;extruder heater off
M84 ;steppers off
;{profile_string}
support_start.gcode =
support_end.gcode =
cool_start.gcode =
cool_end.gcode =
replace.csv =
preswitchextruder.gcode = ;Switch between the current extruder and the next extruder, when printing with multiple extruders.
;This code is added before the T(n)
postswitchextruder.gcode = ;Switch between the current extruder and the next extruder, when printing with multiple extruders.
;This code is added after the T(n)
    I am, slowly, trying to change the setup to a push construction, instaed of the pull concept, because there is so much friction in the short curve at the bottom. The grinding will be related to that I guess..
    Or you could replace the pla at that point by thin steel cable or so.
    The 100 ml syringe (http://www.polyservice.nl/Injectiespuit-p-16476.html) feels easier to push, but has more material to displace, have to test that.
    If it works to push the material, maybe it could work in combination with the Doodle3D box….
    Seems someone had the same idea. A more generic setup for various liquids.
    Also my syringe takes a lot of fraction to operate. That could also be a cause of the grinding. I am more thinking using air pressure to operate it so it will not effect the filament at all. Air pressure I have for my airbrush. There are quite some examples to be found. In order to do this I need to find the right parts....
    This is what finally worked; a combination of different ideas and some of my own.
    http://www.thingiverse.com/thing:14421
    - parts from Joris, some files are old and don't fit any more. The printhead layout changed a lot.
    http://www.thingiverse.com/thing:21302/
    - from mechadense. But with this setup the winding part broke (lots of force here). But this idea works because the use of spectra line through a bicycle/motorcycle brake tubes instead of thick filament.
    I also had to replace the cap of the syringe part by a wooden layered part; the printed one in XT broke...
    chocolate paste extrusion
    pull
    paste extruder setup
    Chocolate paste on a biscuit
    and of course made some spacers for the limit switches X ,Y and Z to prevent collision. Especially for the Z height to compensate for cookies or so.
    z-limit switch add-on
    when placing an object in Cura, mind that the object will not be printed in the center but more to the right and back. This could probably be edited in the gcode as well.
    Here is the gcode, for a chocolate star with cold extrusion:
    ;Sliced ?filename? at: Sun 24-08-2014 13:38:22
    ;Basic settings: Layer height: 0.3 Walls: 14 Fill: 0
    ;Filament used: #F_AMNT#m #F_WGHT#g
    ;Filament cost: #F_COST#
    M302
    G21 ;metric values
    G92 X0 Y0 Z0 E0 ;reset software position to front/left/z=0.0
    G1 Z15.0 F?max_z_speed? ;move the platform down 15mm
    ;go to the middle of the platform (disabled, as there is no need to go to the center)
    ;G1 X?machine_center_x? Y?machine_center_y? F9000
    G1 F9000
    ;Layer count: 1
    ;LAYER:0
    M107
    G0 F9000 X98.55 Y60.53 Z0.30
    ;TYPE:WALL-INNER
    G1 F600 X100.79 Y60.54 E0.01190
    G1 X101.91 Y58.60 E0.02380
    G1 X103.02 Y60.54 E0.03569
    G1 X105.26 Y60.53 E0.04758
    G1 X104.14 Y62.47 E0.05947
    G1 X105.26 Y64.41 E0.07137
    G1 X103.02 Y64.41 E0.08327
    G1 X101.90 Y66.35 E0.09516
    G1 X100.79 Y64.41 E0.10705
    G1 X98.55 Y64.41 E0.11895
    G1 X99.67 Y62.47 E0.13084
    G1 X98.55 Y60.53 E0.14273
    G0 F9000 X99.63 Y58.54
    G1 F600 X101.91 Y54.58 E0.16696
    G1 X104.18 Y58.54 E0.19118
    G1 X108.74 Y58.52 E0.21540
    G1 X106.45 Y62.47 E0.23962
    G1 X108.74 Y66.42 E0.26385
    G1 X104.18 Y66.41 E0.28807
    G1 X101.91 Y70.37 E0.31230
    G1 X99.63 Y66.41 E0.33652
    G1 X95.07 Y66.42 E0.36074
    G1 X97.36 Y62.47 E0.38496
    G1 X95.07 Y58.52 E0.40919
    G1 X99.63 Y58.54 E0.43342
    G0 F9000 X98.48 Y56.53
    G1 F600 X101.91 Y50.56 E0.46997
    G1 X105.33 Y56.53 E0.50652
    G1 X112.22 Y56.52 E0.54307
    G1 X108.76 Y62.47 E0.57962
    G1 X112.22 Y68.43 E0.61618
    G1 X105.33 Y68.41 E0.65273
    G1 X101.91 Y74.39 E0.68928
    G1 X98.48 Y68.41 E0.72583
    G1 X91.59 Y68.43 E0.76239
    G1 X95.05 Y62.47 E0.79894
    G1 X91.59 Y56.52 E0.83549
    G1 X98.48 Y56.53 E0.87204
    G0 F9000 X97.32 Y54.53
    G1 F600 X101.91 Y46.54 E0.92092
    G1 X106.49 Y54.53 E0.96981
    G1 X115.70 Y54.51 E1.01869
    G1 X111.08 Y62.47 E1.06757
    G1 X115.70 Y70.44 E1.11645
    G1 X106.49 Y70.42 E1.16533
    G1 X101.91 Y78.41 E1.21421
    G1 X97.32 Y70.42 E1.26309
    G1 X88.11 Y70.44 E1.31197
    G1 X92.73 Y62.47 E1.36085
    G1 X88.11 Y54.51 E1.40973
    G1 X97.32 Y54.53 E1.45861
    G0 F9000 X96.16 Y52.53
    G1 F600 X101.91 Y42.52 E1.51982
    G1 X107.65 Y52.53 E1.58102
    G1 X119.18 Y52.50 E1.64224
    G1 X113.39 Y62.47 E1.70344
    G1 X119.18 Y72.45 E1.76465
    G1 X107.65 Y72.42 E1.82586
    G1 X101.91 Y82.42 E1.88706
    G1 X96.16 Y72.42 E1.94827
    G1 X84.63 Y72.45 E2.00948
    G1 X90.42 Y62.47 E2.07069
    G1 X84.63 Y52.50 E2.13189
    G1 X96.16 Y52.53 E2.19310
    G0 F9000 X95.01 Y50.52
    G1 F600 X101.91 Y38.50 E2.26664
    G1 X108.80 Y50.52 E2.34018
    G1 X122.67 Y50.49 E2.41372
    G1 X115.70 Y62.47 E2.48726
    G1 X122.67 Y74.46 E2.56080
    G1 X108.80 Y74.42 E2.63434
    G1 X101.91 Y86.44 E2.70788
    G1 X95.01 Y74.42 E2.78142
    G1 X81.14 Y74.46 E2.85497
    G1 X88.11 Y62.47 E2.92850
    G1 X81.14 Y50.49 E3.00204
    G1 X95.01 Y50.52 E3.07558
    G0 F9000 X93.85 Y49.62
    G0 X93.85 Y48.52
    ;TYPE:WALL-OUTER
    G1 F600 X101.91 Y34.48 E3.16146
    G1 X109.96 Y48.52 E3.24733
    G1 X126.14 Y48.48 E3.33319
    G1 X118.02 Y62.47 E3.41906
    G1 X126.14 Y76.47 E3.50492
    G1 X109.96 Y76.42 E3.59079
    G1 X101.91 Y90.46 E3.67666
    G1 X93.85 Y76.42 E3.76253
    G1 X77.67 Y76.47 E3.84839
    G1 X85.80 Y62.47 E3.93426
    G1 X77.67 Y48.48 E4.02012
    G1 X93.85 Y48.52 E4.10599
    G0 X93.84 Y53.52
    G0 X93.84 Y53.52 Z5.30
    ;End GCode
    G1 Z+0.5 E-5 X-20 Y-20 F9000 ;move Z up a bit and retract filament even more
    M84 ;steppers off
    Nice that you posted your wonderfull solution. For the parts that did not fit anymore I just cutout the corner with a saw. But your parts will be more sturdy. Also note that you are using a 100ml syringe.
        • 27 replies
