I had the same issue with mine a week after I received it.
It got to the point I was unable to print. I then decided to inspect the stepper motors. There was dirt/debris in-between the outer housing and the stepper motor. I removed the motor and cleaned the area. When I did this, I also happened to notice some issues with the stepper motor with debris effecting it also. I cleaned everything I could. Reattached everything and sound was gone! It also drastically improved print quality, and I have yet to have any issues in the last 6 months.
Looking at the housing image below, you can see there is very little room between the rotation and the cover. If there is dirt in there at all it causes vibration in the housing :( It would be nice to ventilate or have a cleaning hole with protection cover.
gr5 1,971
It sounds annoying as hell.
With power off, or with power on but with servo power off (they are off most of the time when not printing) push the head around. Try to duplicate the noise and see where it's coming from. Belts? Rods? Pulley slipping and grinding a rod? Motor? Motor pulley?
Try also pushing it around by pushing on the side blocks or just one block and try pushing by moving the long belts or short belt directly.
Are you near the huntington beach in CA? It's important to know what country you are in as customer support is usually faster in USA (at this time, UM CS is hiring).
