If one of the blades is broken it also makes a freaking lot of noise.
all the time, or just in the beginning?
Could be both, depends on where it broke.
Same here now, it is super loud for like 2 minutes(next door loud), and then it quites down occasionally making a little more noise.
I'll try the oil thing, but what if the sticker doesn't stick anymore ?
No experience with my UM fan (although it starts doing some noise as well), but I have done it at least a dozen of time on the fan of my RC power supply, and I still can put the sticker back.
But it will work without sticker (You can always glue it back if you absolutely want to keep a sticker...)
gr5 2,192
Peel off the sticker and add a drop of oil. If that doesn't fix it order a new one. There are several suggested replacement fans on this forum somewhere. Check the voltage (is it 12V? 19V?) first before ordering a new one.
