Dim3nsioneer 557
Please stop staring at the (last) picture before you turn blind... :eek:
I'll try to do some sharper ones later.
The print was made with 0.1mm layer height. I also did prints with 0.15mm and 0.2mm; they look very similar. I can also upload an image of them.
I think the color difference comes from the photo. I mainly care about the thicker/thinner issue because it's this effect which ruins prints with vertical walls.
Until now I considered the banding to be completely irregular but as you see some repeating pattern I have to check the prints again directly.
Top Posters In This Topic
27
15
13
10
Popular Days
Nov 4
17
Feb 4
13
Nov 3
9
Oct 14
7
Dim3nsioneer 27 posts
gr5 15 posts
pm_dude 13 posts
3devos 10 posts
Popular Days
Nov 4 2014
Feb 4 2015
Nov 3 2014
Oct 14 2014
gr5 2,172
Which one? You have 5 pictures. Here is a crop of the most recent picture. It's a good picture but not good enough:
My eyes hurt from staring at this picture. The darker bands seem to have a somewhat regular pattern for example the 5 green lines - you have 3 bands equally spaced, then a gap, then 2 more. This kind of pattern seems to repeat all over the part.
Then looking at the lower 2 red arrows the part seems skinnier aligned with *lighter* regions but the upper arrow shows a skinnier area lined up with a *darker* region. I'm not sure what's going on:
Is it the photo?
Do you care about the dark/light?
Do you care about the thicker/skinnier issue?
Or is it the same issue but the photo isn't good enough for me to tell?
I have a $1000 camera but my cell phone tends to take better macro photography. If you aren't using a cell phone maybe you should try it.
Anyway, I tend to believe you that the problem is z screw related. Especially because the banding seems to be somewhat regular. What is your layer thickness again? I wonder if thicker layers (.2mm) have less banding because screw errors might be less obvious. But if the problem is on a scale of 1mm then .2mm layers won't be any better than .1mm layers and the green pattern appears to be much thicker than .2mm!
