Full Graphic Smart Controller (ebay) + Ultimaker board fix
Posted · Full Graphic Smart Controller (ebay) + Ultimaker board fix
@Amedee, is there any way to reverse the action of the knob? On my unit, turning the knob clockwise decreases feed rate and advances down in menus, which seems the opposite of what the graphical display did.
Weird... Mine is working 'as expected' -- I have 2 UMOs, one with the Ulti, one with this one and they operate the same.
I'll check how/where to change that in the firmware
So far feeling a little less than impressed overall. The graphical main view is nice, but in the menus, the slow update speed kills the advantage of having more lines. I can see why UM didn't hop on switching the Ulticontroller to a graphical version.
I don't see a difference in performance between the 2 devices...
They main reason for me for choosing this one was the price, a fraction of the cost of the Ulti. The main screen is nice, but other than that both devices are doing the same and operate the same.
    • Replies 86
    • Created
    • Last Reply
    To come back on this...
    I believe your board has an encoder with different specs... There is no 'tunable' in the firmware to reverse the action, you have to compile a new firmware...
    Encoder handling is defined in dogm_lcd_implementation.h
    #define BLEN_A 0
    #define BLEN_B 1
    #define BLEN_C 2
    #define EN_A (1<<BLEN_A)
    #define EN_B (1<<BLEN_B)
    #define EN_C (1<<BLEN_C)
    #define encrot0 0
    #define encrot1 2
    #define encrot2 3
    #define encrot3 1
    And I think the correct sequence for your encoder should be
    #define encrot0 3
    #define encrot1 1
    #define encrot2 0
    #define encrot3 2
    But probably the easiest is to swap the pin assignment in pin.h:
    #define BTN_EN1 40
    #define BTN_EN2 42
    change to
    #define BTN_EN1 42
    #define BTN_EN2 40
    I would go with swapping pin assignment, though I might just take a look at swapping the physical connections.
    Maybe just scratching open the traces on the board and bodging it to the correct way. (on the graphical display board, of course. Not the UM board.)
    I bought a SD card, so I should be testing shortly, as soon as I fix my clogged hotend. Since I was not sure whether SD or SDHC makes any difference I dug up a normal SD card. Those are becoming a bit rare. Does anyone know whether that makes a difference?
    Since I slightly damaged the cables I also bought material to make them myself, so now I can put the nubs on the right side. I didn't really mind the filed down nubs, as they fit quite snugly, but I do want the cables themselves undamaged.
    I forgot to update this, but I finally got a chance to test the firmware. It all seems to work like it should. Very nice indeed!
    BTW, to make it simpler and to avoid building for all 'architectures' each time, you can cook you own firmware https://bultimaker.bulles.eu/...
    BTW, to make it simpler and to avoid building for all 'architectures' each time, you can cook you own firmware here...
    Excellent! Will that bake in the fancy Utimaker logo? It still makes me happy whenever I see that.
    Absolutely, the Ultimaker robot is part of the package ;)
    Hey amedee,
    I'm back to using this controller after burring out my ulticontroller. The reason I stopped using it was the encoder being reversed, got annoying. I'm going to attempt to sort it with the firmware fix you posted above. I'm not sure how to update the firmware though, is it by using the controller iteself, or through the ultimaker board? Another option for the firmware builder perhaps....reverse encoder if you select graphic controller?
    Thanks for any help
    The updates are always done via USB on the Ultimaker board...
    For the builder, it would be an easy thing to do, but I first need to spend time in testing my suggested fix...
    OK i'll keep an eye on the builder! If you do get a chance to look into it let me know.
    Ta
    @macua85 I eventually spent some time to look at the encoder thing...
    Hey amedee, thats awesome! I see you've added it to the builder....you're the best! Thanks so much for this!
    Hi guys, trying to install my full graphic controller.
    I'm using the UMO official HBK marlin build, with a few tweaks. I already recommented the Ulticontroller definition and uncommented the one for full graphic controller.
    I have installed this into the Arduino libraries: https://bintray.com/olikraus/u8glib/Arduino/1.18.1/view
    I also installed the Arduino Liquid Crystal library.
    When I try to compile, I get this error. Any ideas?
    ultralcd.cpp: In function 'void lcd_control_version_menu()':ultralcd.cpp:961: error: 'lcd_implementation_draw_line' was not declared in this scope        lcd_implementation_draw_line(0, PSTR(MSG_VERSION));                                                         ^'lcd_implementation_draw_line' was not declared in this scope
    You need to implement draw_line() in dogm_lcd_implementation.h.
    Call was defined by the Ultimaker folks and that's why it is not in the dogm_lcd from Marlin.
    (You can check my firmware branch for more details)
    Posted (edited) · Full Graphic Smart Controller (ebay) + Ultimaker board fix
    Thanks Amadee! I downloaded your branch and compared the dogm_lcd_implementation.h files to find the needed code.
    Sweet, up and running!
    @amedee, would you mind pointing me to the section of code in your firmware branch to get the robot logo? Maybe the new forum took it out from post #5.
    I like the mapping of one knob click, per menu item, but the value changing isn't so great. Is there a section of the firmware that governs the steps / unit?
    Thanks!
    The other thing I noticed is that while most menus are very responsive, the SD card menu is quite laggy. Does anyone else have that issue?
    What about browsing the commit log? :p
    This changelog
    ENCODER_PULSES_PER_STEP in the config file. By default one encoder pulse  generates one unit step in the values.
    Difficult to find a good compromise there, if you increase it, you will have to turn a lot to make big changes...
    Also, ENCODER_STEPS_PER_MENU_ITEM relies on that one, so if you change the first, it will affect the menu browsing as well, so you need to tune both.
    Personally I wouldn't go there...
    This changelog
    Ah yes, that makes perfect sense now! I'm a github noob. :)
    Both those lines are commented out in my config. It seems simple enough on the surface: tune pulses / step to give the behavior desired on value setting, then use steps / item to to get menus working again. I'm guessing the reality isn't that simple. Are these variables hardcoded elsewhere when not defined here?
    Does anyone know how many knob encoder pulses are generated per detent position? Maybe it even varies depending on controller mfg.
    Yes, it's 1 / 5 respectively when not defined (same as what it is in the commented lines)
    Probably. But having an UtliController on one machine and this one on the other, I don't feel much difference.
    The only other references to those variables I could find are these. It looks like if not otherwise defined pulses / step is 1 and steps / item 5.
    People seem to be having good luck with pulses/step @ 2 and steps/item @ 4.
    I'm guessing that these need to be integers. Kind of tough in that case to get exactly what you are after. Seems like you can end up with say every 4th knob click not causing a menu change.
    ultralcd.cpp:
    #if !defined(LCD_I2C_VIKI) #ifndef ENCODER_STEPS_PER_MENU_ITEM   #define ENCODER_STEPS_PER_MENU_ITEM 5 #endif #ifndef ENCODER_PULSES_PER_STEP   #define ENCODER_PULSES_PER_STEP 1 #endif#else #ifndef ENCODER_STEPS_PER_MENU_ITEM   #define ENCODER_STEPS_PER_MENU_ITEM 2 // VIKI LCD rotary encoder uses a different number of steps per rotation #endif #ifndef ENCODER_PULSES_PER_STEP   #define ENCODER_PULSES_PER_STEP 1 #endif#endif
    Also found this guy. I had wondered why I had to turn the knob so far (even with the UC) before getting a feedrate override:
    ultralcd.cpp:
    #define ENCODER_FEEDRATE_DEADZONE 10
    I can confirm that:
    configuration.h
    #define ENCODER_PULSES_PER_STEP 4 #define ENCODER_STEPS_PER_MENU_ITEM 1
    ultralcd.cpp:
    Work very well.
