Almost certainly the problem you are having is not with the nozzle being blocked; since you could push filament out by hand, the nozzle is fine. Check the filament at the extruder motor end at the back of the printer, and make sure it isn't damaged. If the filament is rubbed away or has gouges and deformations, make sure you cut those off.
What material are you printing with?
IRobertI 516
Just use a random stick/screwdriver/whatever and push the wires aside, no big deal. And/or pull a little on the wire harness and see if that moves the wires out of the way.
