I think this is a problem with the newer Cura versions. I get this smeared top (albeit not that bad) on all objects with a round top. However, I have other objects here that were sliced with Cura 14.02 or .03 and they are fine.
One way to circumvent this issue is to either use the "Cool head lift" feature (but then you'd have a seam of surplus filament on one side).
IRobertI 516
There could still be a problem with the file. Different slicers deal with file errors differently. A file that works fine in cura might not work well in MakerWare and vice versa.
Regardless of that I'm guessing there's also a cooling issue. On small tips like that the right fan of the UM2 tends to miss the target (as the nozzle is off center). Consider printing two copies of your object at once and also make sure that your fans are going full blast when the printer reaches the tip of the print. You could also try decreasing the print temperature if you can do that without causing under extrusion.
