I'm a bit confused, are you saying that the support type changes from "grid" to "lines" when you change the infill percentage?
If you're just talking about the actual infill, then yes, like George says it changes at 25%. This shouldn't affect the support though and doesn't for me.
gr5 1,872
I don't think so. There is a sudden switch at 25%. 24% does one pattern, the other pattern starts at either 25 or 26%. I think 25%.
You should never be surprised at print time. Always check what's going to happen in layer mode. It may seem like a waste of time but 1 minute in layer view will often save you hours of printing.
