I dont code in C++. I dont code in ny multithreading languages to begin with.
Even if i did, i would still have no idea how to get it done.
I guess i quit for good since CraftWare needs options for support. Other then that its perfect.
Cura needs no options for support but the perimeter print. Other then that, its perfect.
Too bad i cant generate good support where i need as well as have perimeters printed one at the time no matter what application i use.
Maybe Kisslicer or Slic3r do that i dont know, but if they do, i dont like them because they are not user friendly.
Dim3nsioneer 557
As Daid is currently working on the UM2 dual extrusion too, work on Cura is certainly slowed down at the moment. Therefore, I wouldn't expect him to change something soon (but maybe he has plans for the PU edition).
As I understood in the past, you're quite good with C++. As the engine code is written in C++, may it be a possibility for you to have a look into the code and make the changes yourself? Daid would certainly consider to implement it if it works properly and if you issue a pull request.
