wow! fantastic i never seen that visual guide!
wel... looking the guide i suffer of:
Under extrusion
Pillowing (but no so pollow)
i'll post my photo to let you underdstand better.
Under extrusion
Too fast speed with too low temp and you're not using retraction?
All with retraction enabled and temperature of 232°C. The little object is been printed today with very high speed (something like 120mm/s just to try) And the bigger object at 80 mm/s.
to summarize:
Little Object. PLA 232°C - 0,1mm layer - 120mm/s speed - retraction enabled
Big Object. PLA 232°C - 0,2mm layer - 80mm/s speed - retraction enabled
Approximately same results.
Way too fast I think. Also the temperature is too high for PLA, I think you are risking deformation of the teflon spacer which could lead to even more underextrusion than I see in the pictures.
I would suggest establishing a baseline using say: T=220°C, speed=50, retraction enabled, 0.1mm layers, 0.8 or 1.2mm shell thickness, ditto for bottom/top layer thickness.
When you print 0,2mm layer - 80mm/s, it's 0,2 x 80 x 0.4 (nozzle) = 6.4 mm3/s.
To get an idea how fast this is you can print this test;
http://umforum.ultimaker.com/index.php?/topic/4586-can-your-um2-printer-achieve-10mm3s-test-it-here/
The Um2 should handle 80mm/s for 0.2mm layers at least mine does (easily) maybe you should check if your nozzle is not partially blocked (look for atomic method).
It's also good to print the test cylinder as suggested by Arjan
I'm printing now with these settings. As soon as it finish i'll post a picture.
What is the Atomic method?
I downloaded the cylinder and i'll print it too soon.
Should shmood!
Better IMHO to establish a baseline: find out what your printer can really do right now. Then consider if that's good enough and what might be done if not.
Atomic method:
http://support.3dverkstan.se/article/10-the
Try the cylinder test first it will tell you how good or bad your extrusion rate is
Ok with the DonMilne setting the printing has improved in quality.
I did twice the test cylinder (great idea) and is totally disappointing...
@230°C
I can see underextrusion almost since the beginning and then at the end of 5mm3/s the levels do not stick together.
Second attempt same settings (just to be sure)
http://umforum.ultimaker.com/index.php?/gallery/image/9192-test-cylinder-second-attempt/
I think i will try the atomic method as suggested to improve the cleanliness of the nozzle.
Once the nozzle is cleaned do the test cylinder again to see if any improvement show.
You can also do several changes that improve extrusion like installing the feeder that lRobertl created (you can find it on youmagine).
One more question, what is the brand of filament you use? Are you sure it's 2.85mm? I had a member of the french forum that was struggling with under extrusion it turned out that he used 3mm filament that has much more friction in the bowden than the recommended 2.85mm (Ultimaker, Colorfabb, Faberdashery and many others)
mhm.... the Atomic Method gave me a strange final result.
I followed the instructions for pla and at the final step when you have to pull the filament, i received a streatched messy filament. (I'll post photos).
And a strange commond deformation to all 4 attempt.
You maybe need to let the filament cool a little more before pulling it out. Perhaps let it cool another 10C. At the moment it's stretching life toffee instead of pulling out cleanly.
Do you feel any obstruction when using the atomic method?
when i push the filament at 260° it flows well but i can't figure it out if just above the nozzle is full of dirt or former filaments residuals.
You need to do the atomic method at a colder temperature. It should be a perfect cone shape tip. Not like these.
Note that you might need a new teflon isolator. These get deformed after many months of use. Ultimaker has newer ones that are built out of a better material now.
Also is your role of red PLA getting near the end? The tighter radius of curvature on the spool of filament can also cause problems. Try printing the cylinder with your other PLA.
I hope to find some teflon replacement @ Maker Faire Rome from Ultimaker stand! Is it something ultimaker provide to all the former printer or just by request?
Today i'll try to wait more for the atomic method and see what happens.
The red pla is almost at the beginning... but i noticed that is a little big even if shipped by ultimaker.
is this the new teflon isolator?
https://www.ultimaker.com/products/um2-parts-ptfe-isolator-coupler-glass-filled-3-dot-2-mm
Yes.
Try cold pull (atomic method) at 90C.
How full is your filament spool? 10%(mostly empty)? 50%? 90%(mostly full)?
Cold pull at 90C is what i've made so far...
The filament is almost full...
Try 85C then. You should need at least 1kg of pull and It should look like this:
also done at 70°. A little better but always like a toffee...
Now i changed filament to try the test... and the results are even worse...
gr5 1,968
Please post a picture.
Do you mean like the first picture here?
http://support.3dverkstan.se/article/23-a-visual-ultimaker-troubleshooting-guide
If so the solution is also there.
