Bronzefill, under extrusion. frustrating!
daveholbrook
Posted · Bronzefill, under extrusion. frustrating!
I'm still attempting to get a decent print with bronzefill, and after a couple of really frustrating weeks I thought I was there. Im printing on an UM2 at a temp of 220, with flowrate of 104%, fans of full. Everything goes fine for start of the print and then I get under extrusion for the final 25%. anyone have any ideas? very welcome.
Below is an example of this.
Baby Scan
Cheers,
Dave.
    What are the other settings you use?
    I don't know if you saw these tips on colorfabb's website:
    http://learn.colorfabb.com/print-bronzefill/
    I used the profile they give for the UM2 and increased the flowrate a bit i think to 107% but not sure about that value. I had no problems printing with BronzeFill but i would recommend to clean the nozzle with the Atomic method between prints to prevent partial (or total) nozzle clog.
    Please detail more of your setting.
    Print at least at 50mm/s otherwise you will get progressive buildup in the nozzle and progressive decrease in the flow of material. Same rule goes with Woodfill Fine.
    Sorry, I didn't give much detail on my settings (screenshot below).
    also forgot to mention that i'm attempting a 100% infill model.
    I have cleaned the nozzle after clogging, but what is the "atomic method"?
    cura settings
    Thanks,
    Dave
    The atomic method in a few steps is:
    - Remove the bowden tube from the top of the print head
    - Heat the head to 230C or so (Depend on the clogged material).
    - Insert some filament by hand (I often use Nylon or PLA) and make sure you have enough to be able to pull it out later. Use a light color filament to see what comes out.
    - If you have a needle or wire that can fit in through the nozzle hole (less than 0.4mm wide) insert it a bit but dont push the inserted filament out. This will help retain the material inside for a better pull and can also help push the clog.
    - Push on the filament, reduce the heat to around 90C and maintain pressure on the filament.
    - When the head reach 90C pull the filament out.
    Repeat a few time if the tip of the filament doesn't come out clean.
    Bronzefill is about 5X more expensive than regular PLA so unless there is a real need for 100% infill I really don't seen any general need for that. The material is pretty stiff and 10-20% infill with a thicker shell is mostly enough for bronze even if you polish it.
    The 50mm/s in speed I refer to is when printing at 0.15mm layers so you will probably need to print even faster with 0.08mm layers to keep the material to flow.
    When polishing bronzefill you can most of the time remove completly the print lines.
    As pm_dude said i wouldn't print bronze with 100% infill i'd use max 24% if the infill is really needed, if not probably go down to 10% or 0% :)
    I don't think it's usefull with bronzefill to go under 0.1mm layers, after cleaning you won't see the lines anymore. Colorfabb's profile for the um2 is:
    layer_height = 0.2
    wall_thickness = 0.8
    retraction_enable = True
    solid_layer_thickness = 0.8
    fill_density = 20
    nozzle_size = 0.4
    print_speed = 50
    I went with these settings (and adjusted the flow a bit) and it went perfect with no clogs at all.
    Maybe try with 0.15mm layers if you want it to be more clean and keep a good speed
    Thanks chaps, I know what you're saying about no need to print 100% . My only reason being was to achieve a heavy feeling model.
    Cheers,
    Dave
    Its 3X heavier than most PLA.
    3.9g/cm3
    I'm still not sure what it is I'm doing wrong. I've done all of the settings as mentioned but am still getting under extrusion, with the annoying clicking sound as the material is failing to feed.
    which extruder feeder are you using ? Bronzefil is quite stiff in comparison to normal PLA
    my printing improved vastly with a change to the feeder, there are several designs available
    I wasn't aware of different extruded feeders? Is this the wheel which feeds the material yes? If so then I'm just u sing the standard one that was on my UM2 when I purchased it.
    Yes its the black part on the back of the machine
    I have three different models of feeder that I have printed, in fact today I installed one I printed some time ago, I am currently printing my first hand from E-Nable which is about 20+ hour of printing. I had on very large part fail so I decided to changed to the new design extruder and its working like a dream http://www.youmagine.com/designs/2904 the belts give that extra push to the filament.
    There are many other designs out there that people swear by too, search youmagine
    your under extrusion problem could be caused by a number of things, loosening the screws on the top of the print head can sometimes make a difference, just finger tight, the same for the four screws that hold the feeder in place (black bit at the back) in both cases the thinking is that if they are to tight they could cause some distortion which could effect the extrusion. The tension setting on the feeder should be set to minimum - thats the highest position there is a scale visible on the back and side of the feeder.
    if the above doesn't fix things then I would recommend removal of the feeder and check inside for filament dust (from grinding the filament)
    To remove the feeder you must remove the left white metal cover panel first (single screw on left side of printer) then the four screws that hold the feeder in place as you remove the last on the stepper motor inside needs support or it will drop. Check around the bearing inside the elbow (white piece) for dust, I even lubricate this from time to time
    good luck
    Hi Dave,
    I think the problem might be your model is really tiny. This probably means the minimal layer time will determine the max print speed and not the set 50mm/s.
    Now when the print speeds slows down the filament will move even slower through the hot-zone, allowing heat to migrate through the filament. This can cause some issue with the teflon coupler, especially if it's already worn down. Have you every replaced the white Teflon coupler?
    My tip for printing this specific model would be to print maybe 2 at a time, or increase the scale. Both options should result in faster printing.
    Another way could be to adjust the minimal layer time down, so it'll allow for the 50mm/s. But if your model is too small it can't cool down.
    Excellent point. Put the minimum layer time to 0 to dissable it. Check the estimated time difference.
    Thanks everyone. I've now managed to print a successful bronzefill model (taken from thingiverse). I reduced the infill to 20% and put the speed up. I gave the nozzle a very good clean out before printing and everything went fine. Pics below.
    Once print was finished i sanded back with wet and dry, then used a wire brush, then scotch brite, then final polish with wire wool and brasso. Once dried i then treated the model with gilders paste before giving it a final polish.
    DSC 2073
    DSC 2070
    DSC 2068
    DSC 2067
    DSC 2066
    Thanks again everyone for the help.
    Dave
    Ho s*** that's pretty shinny :D
    Good to hear you managed to print for good!
    That looks Awesome!!!
    very impressive piece of work :cool:
    Yeah nice! I`m heading to London tomorrrow and am planning on stopping off at the imakr store, hopefully they have some bronzefill :)
    Glad you got it working! Just ordered some and look forward to using it. I am curious though as to how a bronzefill print sounds when it's dropped? Metallic at all or still pretty plasticy?
    Probably more like concrete. I never tried to drop it ^^
    What i can tell is that it feels more real, because it's heavier... It doesn't feel as "cheap" as regular PLA
    .......... I am curious though as to how a bronzefill print sounds when it's dropped? Metallic at all or still pretty plasticy?
    It has a metalic sound when knocked against a desk for instance, its a lot heavier than plastic,but it is more brittle just had a piece break in half never happened with the same item in regular PLA
    still it looks great when polished up
    Are you using the 1.75m material? Everytime i look for this material I can't seem to find 3mm
    Thanks for the feedback guys!
    I ordered 2.85 mm in the USA at 3DUniverse. You can also find other resellers on Colorfabb's website. I too noticed some of them only sold 1.75mm though.
    http://shop3duniverse.com/products/colorfabb-bronzefill
