The vertical dotted line is a in model travel move. No retraction is caried out. I don't know if you can influence this in expert mode. Since it is done in the infill area not much harm is done. It is quicker to not retract so that is likely the idea behind it.
I don't know what the problem is with the first layer fotoos. The thing that I see is a flow that did not stabelize in the beginning. Correct me if I am wrong..
LePaul 336
I'm also noticing the "dotted line" , so wondering if the retraction isn't enough or...something?
I have it at the defaults for High Quality printer, lowered the temp to 212 a bit ago once the brim was done.
Note top, going from right to left
