Dim3nsioneer 556
Yes I had combing enabled. Damn! If disabling combing is the solution, then that's fantastic! :smile: I shall try your settings shortly on my next print.
Do this, but don't blame me if the print fails... :wacko: Good luck!
I won't ;-) I'm just very grateful for your pointer :-) I've been having lots of problems with XT blobbing. Hopefully this will go some way to prevent that. Thanks!
Update:
Dim3nsioneer.... +1 I think you may have solved the blob problem. You lovely lovely person.
The fill looked hugely better with no blobs. I've still to re-try the print that was giving me real problems and as I don't wish to tempt fate... I'm going to just shut up about it until it's printed.... :-)
Update:
The fill looked hugely better with no blobs. I've still to re-try the print that was giving me real problems and as I don't wish to tempt fate... I'm going to just shut up about it until it's printed.... :smile:
Ooohhhh...that's just a bit too much for a Sunday evening... :oops: But I'm glad it worked (hopefully!) for you... :-P
Looook.... this is the start of my Nemesis print.. no... blobs
:-P
Why is it called combing?
Maybe the movement effect is analogous to dragging a (hair) comb over a surface? (I don't know - just wondering)
http://www.pomades.com/p/438-034-00/imperial-dax-pocket-hair-comb.html
Why would you want to turn that on?
Because it's faster without retraction...
its called combing maybe because if you print a comb and combing is on, the head stays within the teeth. With combing off, the head would cross over the teeth, choosing the shortest way…..
Ah, maybe it could be called "no space jump"
Combing is great in most cases but I would like it not to occur on the top surface of the infill. It looks like scratch on the surface.
Its not only reducing retractions. Combing also try to force head movement to stay on the surface (infill only).
I which there was a mode that would comb on the shell too to see if it can help in some things like the FairPhone cases for instance.
Dont get too exited, retraction and plugin "retract while combing" are distance based.
If you want to retract from place to place (perimeters for example) then you are screwed.
Tweaking the distance will help but models are not always square boxes, so distance changes, thus making those distance settings useless.
Dim3nsioneer 556
Have you enabled combing (expert settings)? If yes, disable it and use reasonable numbers for minimum travel distance before retraction and minimum extrusion amount... I use 5mm for the first and 0 for the second.
If you get blobs on top then avoid z-hopping.
chrisr 18
Yes I had combing enabled. Damn! If disabling combing is the solution, then that's fantastic! :-) I shall try your settings shortly on my next print.
