Oh and one last thing. Sometimes depending on the material, one of the factors above was temporary such as temp and speed but it caused grinding. This causes the knurled bolt to be packed with ground material which made additional grinding/slippage more likely at only slightly too cold or slightly too fast printing.
anon4321 16
I've found the UMO feeder to be fairly reliable. If you are getting chewing, it could be due to a few reasons:
Printing too cold
Printing too fast
Printing too cold and fast.
Filament might be too large. Measure with calipers, needs to be 2.85 or thereabouts. If it is more than 3mm, it can jam. Measure it at different spots as well as at different angles around the filament in case the filament is oval.
Nozzle could be partially clogged.
The plastic insulating elements in the nozzle are deformed from too much heat.
The feeder pressure is too high squishing the filament into more of an oval and the oval shape at it's widest part is wider than 3mm.
If the feeder pressure is too low.
In my experience, it has been too cold or too fast or both and occasionally it has been a clogged nozzle.
