I started having underextrusion and its clearly not due to the feeder. I've been using Roberts feeder for months and it works great.
In my case the nozzle was having trouble dealing with PLA/PHA filaments even at low speed and higher temp while Ultimaker PLA was doing great even at high speed. Something to do with viscosity I guess. In the end my nozzle was a mess even if atomic pull was coming out clean most of the time.
Even the change filament procedure was causing the feeder to skip backward on those filament.
You might just not have nailed the good tension with the feeder.
Labern 772
If you are still having under extrusion problems with Roberts feeder then maybe something else is wrong.
with the right settings you shouldn't have any problems and none bad enough to warrant having 2 motors
