This is my line of thinking:
A little slag in the belts or a slight wobble in the pulleys can explain the differences. When you have 1 or 2 objects close
together then the probability of printing in a trouble zone is small. But if you fill the bed then there will be areas that are good and bad. Your photo also shows correctly printed parts not all of them have the same artifacts.
korneel 175
it might have something to do with layer adhesion and cooling off.. the beads have cooled off so much that essentially you are starting a complete new layer, without "fusing" them together..
i would recommend placing them apart and using the print separately option in Cura.
