I have the best results using garnier fructis ultra strong hold en flex no.5 hairspray all the other hairspra etc sucks .( just one coat on the bed ,not to much)
Fo big objects to print in abs i use also mouse ears or brim ,and ofcourse the heathed bed atleast 100c.
And maybe colorfabb xt is the answer for you its alot easyer to print with
IRobertI 520
What would you say is the major issue you're having? I see you mentioning warp, is that the only problem? Pictures of the failures will help in figuring out what's happening as well as examples of objects you're trying to print.
