Thanks for the videoI followed your guide, took it apart, it didn't 'seem' like there was anything wrong with it... not much gunk between the brass and the teflon like I thought.
But there was more friction on the teflon than I expected so i used a small cylindrical file and really lightly enlarged the bottom part a tiny bit. I put it together and its printing better now.
So I guess it's solved for now! will update if problems persist.
DidierKlein 726
It's quite easy to take the teflon out, it doesn't take that much time
Check out this video for the steps to follow:
I had a similar build up of burned material at the bottom of my teflon i cleaned it with a cutter, you can also take that opportunity to check if there's friction inside (pass a piece of filament and see if you feel any friction).
If yes you can drill it out a bit
