Check how it renders in cura's layer view.
i had really strange slicing issue with cura lately, namely the 5mm Qbert stairs calibration model was rendered with rightmost stairs 3mm wide instead of 5, and i finally realized it was sliced this way by cura !
as a rule of thumb, always check the layer view before printing : maybe your printer prints just what it has been told to.
nallath 1,120
These are usually caused by backlash. Check the tension of your belts & tighten your pulleys.
