Hi Chuck,
There are no way to change the filament during the print unless you changed the feeder with one that let you manually feed the filament in and out of the bowden tube.
Here is the one I use:
https://www.youmagine.com/designs/alternative-um2-feeder-version-two
Once you have a feeder that allow you to manually feed you can then pause the print at any point and change the filament. You can use the pause at z plugin to pause at a specific height. You will need to manually purge the nozzle with the new filament before resuming.
chuck-yanke 9
Miss typed title should be "Changing color in middle of a print". Fat fingers, sorry.
Chuck
