Warhammer 40k leman russ destroyer
wlock
Posted · Warhammer 40k leman russ destroyer
I initially bought the Ultimaker2 because of its amazing quality prints but I have to say that the more I see pictures on this forum the more I am surprised at what it can do
Regarding this project:
GW decided to change the leman russ model and I dont really like the new tracks, they seem less detailed than the old one so i decided to make my own
The model will be a destroyer, and is a work in progress
It's designed to avoid support structures
the black model is actually the original destroyer from forgeworld that I use as a reference
leman russ side track plate
DSC 0207
DSC 0206
DSC 0205
DSC 0204
DSC 0203
DSC 0202
DSC 0201
DSC 0200
DSC 0199
DSC 0198
DSC 0197
DSC 0175
DSC 0174
DSC 0173
DSC 0172
DSC 0171
DSC 0170
Paint is just to see what potentially it could look like once finished,
I'll need to practice a bit more to make it presentable
software used
Maya 2009
cura 14.12
Model resolution 0.05
print speed 30mms
White PLA from colorfabb
temp 190
bed temp 40
    That turned out amazing! Well done!
    thank you all for the comments
    I'll put a few pictures on that other post once it's finished
    I realised i forgot to add a few screenshots of the actual 3d model so i added them now.
    The main hull overall size and shape are done.
    The front plate is also finished and is ready to receive either the main gun or the demolisher option.
    the base for it is only two layers thick( at 0.05) so it can be placed on top of the main hull.
    The engine section is there but its hard to print because of the slope on several directions. trying to figure out how to print that
    DSC 0220
    DSC 0215
    DSC 0214
    DSC 0213
    DSC 0212
    DSC 0210
    DSC 0209
    3dmodel5
    3dmodel4
    3dmodel3
    3dmodel2
    3dmodel1
    3dmodel
    I find this model amazing, is there any chance you could send it over? I could really use this in my imperial army. Nicely painted by the way.
    In a scale of A to 10, I find this model and paint job to be really sweet :)
    And, I am unanimous in this :p
