Hi, i am just finished with building my um+, I don't understand where I should put this delrin clip.
Can someone send me a picture? Maybe this is my problem because my first print of the robot came out as weird square!
I ran without delrin clip, but it seems fine with 2 hours printing. Thanks for the hint for re-making a delrin clip, I'll try and make one to put it on.
Now after some test prints, I found some PLA seems leaking from the Peak and spreads onto the aluminum part above the nuzzle. Can I know if this is ok? or this is the cause that the print quality is far below my expectation? Also any suggestion how to clean it and prevent it from leaking again? Thanks.
Matt
also, there are always some black burn mark on the print, please see the pic below, any solutions? Some of them are only black burnt mark but some did dissolve the surface, seems like the nozzle touched it?
what filament are you using - I don't think that is burn marks but the 'leaking' that you are referring to which to me looks like your nozzle assembly may not be quite tightly done up so that it is sealed (tighten carefully but firmly).
Heat up the head and wipe it with a cloth - careful it is hot!
Some of my filaments seem to produce some 'gunk' which burns on the nozzle - so a regular wipe before printing.
Not sure which materials cause it as I use so many and regularly change nozzles - and sometimes oil filament like ninjaflex.
So it is not burning - but 'dripping'.
thanks, I do have some leakage from the tube onto the aluminum square and some black on the nozzle. I'll try to wipe out the leaked material first and tighten it up to see how it goes.
For the material, I'm using the filaments from Ultimaker directly, will it be a problem for this?
leaks can cause these brown marks : you are cooking PLA on the Alu block / Nozzle, and the resulting goo drops on your print.
tightening will solve the problem, but by all means, DO IT WHILE HOTEND IS HOT
i broke may nozzle on day one by trying to tighten it cold after i noticed material oozing.
I've done the tightening for 3 times with cold hot end now, but still got same leaking. Will try hot to see if it improves. Can I know why it has to be hot? just curious?
I had/have exactly the same issue with the nut of the feeder on my newly assembled UM+. It keeps working itself loose during printing and eventually falls off - the gear works itself out of alignment and extrusion obviously stops. I have tightened it as much as I dare and the delrin clip is really snug, so yes, I am also worried about it breaking. So far the only solution I have reached is tightening it every 3-5 prints or so.
I also had the oozing on top of the alu nozzle block - I followed the instructions for tightening whilst hot on here and that sorted it out.
Wonder who else is having these issues with their UM+ kit?
I already told you in the other thread, if you are tightening against the clip your build is basically wrong and you will break it soon or later.
The clip is just there to keep the axis in place and no force should be applied on it...
is there a stl file of a delrin clip? Mine is broke but I have an other printer, so maybe I can print myself another one?
gr5 2,192
Please post pictures. Your words don't make it clear to me and I'm too lazy to read your words and look at my machine or assembly instructions if you are too lazy to post pictures.
I broke the same delrin clip on my UMO. To make a new clip I took a sheet of plastic that was the same thickness and drilled, sawed it to the same shape. It works great. I don't remember where I got the plastic - it was from some old electronics thing or maybe something in the recycling bin.
