Note that temperatures around 60°C are normal operating temperatures for many electronic components.
I mean the component's body temperature when it operates, not the ambient temperature.
The cooling of the UMO is only needed because of the stepper drivers. They got too hot, which caused missing steps. The stepper drivers of the UM2 electronics don't get as hot (don't ask me why), so they remain well within their operating specs without cooling.
The UM2 electronics have the stepper drivers directly on the mainboard. That means the drivers can dissipate heat directly into the large GND plane of the mainboard, instead of just having the tiny area of Pololu drivers.
These drivers aren't meant to need forced air cooling, they just need a large enough GND plane to dissipate their heat
Doesn't the UMO+ still use the carriages?
Carriages?
I read that the UMO+ comes with the UM2 electronics (drivers on board).
I believe aviphysics is asking if the drivers are socketed like a Pololu A4988 Stepper Motor Driver carrier.
My understand is that the UMO+ comes with the UM2 electronics and that the UM2 electronics have the drivers surface mounted with the rest of the components. As such, it would be hard to upgrade/change/replace the drivers on a UM2 or UMO+. The upside is that the current control is done electronically.
IRobertI 514
The UMO+ uses the electronics from the UM2 which should not need additional cooling unless you're in an unusually hot location.
