Hello,
I'm a French user of Cura 15 (and previous..) on a Leapfrog Creatr Dual.
Cura is the only Software I can use On the Leapfrog for Production ( I greatly thank's the Ultimaker Team, who stay in the RepRap Spirit..).
I show you the specs.
System Win 7 - 64bits.
Last Arduino Drivers
the USB on my machine is on Com 8 / 115.000 bauds.
Gcode : Reprap (Marlin/Sprinter).
I use the Printer with ABS from Color fabb, the results are ok for me ( for my use..)
For Colorfabb ABS and mechanical Part:
Layer : .25
Shell : .70
Width top / bottom : .75
Fill : 80%
Temps : 232°C
Bed Temp : 80°c
Brim : 10 turn...
Dia filament : 1.75
With 95%
Advance Conf :
Dia Nozzle : .35
Retract speed : 40
Lenght : 4.5
Quality :
1st layer width : .2
Width line for 1st layer : 100
Speed :
Pos. Speed : 60
1st layer : 20
Fill. speed : 60
Top / Bottom Speed : 30
Ext. Shell : 40
Int. Shell : 60
You can see some printing with the printer on : www.b3ddesign.com
the large FDM part are printing with the Leapfrog, as the engine manifold and some other parts...
No Warping is very difficult to obtain, you need to "close" the printer to maintain the temp.
To fix on the bed I'm using Blue Tape, very good.
don't hesitate contact me on our web site for more information.
gr5 2,210
We aren't leapfrog experts - you need to find out what gcodes set the heaters for the leapfrog. Then for now manually edit the gcode file (it's just a text file - easy to read and edit). Then after confirming that it works you can let us know in the forums what gcode controls heat and to use the gcode. Normally according to this:
http://reprap.org/wiki/G-code
M109 S210 sets the nozzle temp to 210C
some printers use M104 - but for Marlin that's bad because it returns right away and doesn't wait for heatup. M109 waits for temperature to be reached before continuing printing.
M190 S50 sets the bed temp to 50C
(similarly M140 sets the temp and doesn't wait)
and
