Cura outputs incomplete G-code
zumfab
Posted · Cura outputs incomplete G-code
After trying to deal with the problem described here (http://umforum.ultimaker.com/index.php?/topic/9478-umo-bed-does-not-lower-every-time-after-print/) I noticed the problem might be something different completely. Upon opening the G-code file of the troublesome print, I noticed the 'footer' found in other files was missing.
Weird thing is that it is semi-random, but not completely. Whenever I delete the G-code file and rewrite it, the same incomplete file appears. This, to me, suggests that there is some kind of generation issue. One way to 'fix' it seems to be to move the object over the build plate and rewrite. Sometimes another partial G-code appears, but sometimes it does what it is supposed to do. It happens quite regularly though, and can be quite annoying, especially because it limits the control I have over the printing process.
Is this a known issue? Cura seems to work fine when it works, it just stops short of a full file sometimes. Please note that this is happening under Cura 14.07. I just installed Cura 15.02.1 to see whether that changes anything.
    Could you be removing the SD card too soon? Before everything is written? Or maybe it is a defective SD card?
    It sounds like you need to inspect the file on the SD card after saving it.
    It is neither of those, because I make sure to write the file to the hard drive first. The fact that Cura writes the same incomplete file twice confirms this idea, as a troublesome hard drive would not be expected to fail in the same consistent manner. Not only that, but you would also expect other obvious problems.
    I have started inspecting every file I print, but I would rather solve the problem than mitigate it. As I did not get to printing today, I cannot say whether the new version does the same.
    The ball is probably in my court now, but if anyone has any other ideas on what might cause this they are welcome :)
    I finally remembered to save two logs from different parts. At first I though it had to do with print length or plugins, but neither seem to be the case.
    Running: C:\Program Files (x86)\Cura_15.02.1\CuraEngine.exe -v -p -s initialSpeedupLayers=4 -s minimalFeedrate=10 -s preSwitchExtruderCode=;Switch between the current extruder and the next extruder, when printing with multiple extruders.
    ;This code is added before the T(n)
    -s supportXYDistance=700 -s insetXSpeed=50 -s retractionZHop=0 -s extruderOffset[3].X=0 -s extruderOffset[3].Y=0 -s postSwitchExtruderCode=;Switch between the current extruder and the next extruder, when printing with multiple extruders.
    ;This code is added after the T(n)
    -s retractionSpeed=40 -s filamentFlow=100 -s infillOverlap=15 -s inset0Speed=50 -s coolHeadLift=0 -s extrusionWidth=399 -s upSkinCount=10000 -s initialLayerSpeed=20 -s minimalLayerTime=5 -s infillSpeed=50 -s supportExtruder=-1 -s fanSpeedMax=100 -s enableCombing=0 -s fanSpeedMin=100 -s supportZDistance=150 -s supportEverywhere=0 -s filamentDiameter=2850 -s initialLayerThickness=300 -s supportAngle=-1 -s fanFullOnLayerNr=2 -s extruderOffset[1].X=0 -s extruderOffset[1].Y=21600 -s layerThickness=100 -s endCode=;End GCode
    M104 S0 ;extruder heater off
    M140 S0 ;heated bed heater off (if you have it)
    G91 ;relative positioning
    G1 E-1 F300 ;retract the filament a bit before lifting the nozzle, to release some of the pressure
    G1 Z+0.5 E-5 X-20 Y-20 F9000 ;move Z up a bit and retract filament even more
    G28 X0 Y0 ;move X/Y to min endstops, so the head is out of the way
    M84 ;steppers off
    G90 ;absolute positioning
    ;CURA_PROFILE_STRING:eNrtWktv20YQvhJGf8QeEzRWSUqKkwi8JLV9SYIAdtHEF2JFrsStSS6xu7QsG/rv/Xb5ECXTrdMYzYs62ODHmZ3ZmW8ehpXSNZNhwvgy0YE78pwVTdNQJzy6zJlSgTfyHcm0pJHmIg9ZTucpC85lyRwlUh6HqT2go+AsOE6IWa64Xgee6zq5uLlJWaj4DYOJiVNInutQFYzFwdStHzXLCiapLiULfK8H9YMecNwHTvrAaQvOWbxj7ch1VFkUQurgvciZU6RUL4TMQhonTOHWwWvJs0YmjEuahuxay7J6J3TirHjBQi1WTAYnNFWsA4RXIi0zFnhTR4gbRCHhLI1rMYSKZgw+xRy/NdT90YvpXdjc/Q447gMnfeC0Cy5SsbJp6aS1ysXEHe2gNBNlroPJaNpF7f3rV97z3XcZz0M8XLEUxNl5E4lszvNlxZxdDZ7tBBRO7FAuEYXBnLnQWmQdprmjsWPZ54YrHuskXEBDSHs3Mf+LReAYzy+tsrhiMqWFdd7QfOpUbtY396YdCxWjqxe+6/DcErp6NmKW91Qy2sF4rph294HrDhAJkdr41AXDwQlkmjY1FddFdcnBsZTnDCGzIa6hJS2CsbFun5qwpSxf6qT23xy2KOFrW86VgfqOrrt9CjN6bZHWrQVQFASIWoMJo6huvtA1V6ty18hGp/qrkFWIDVMdaEP3pmD0umDBqeRxi9B8iSbyvK270KpW1rd612sQWGmaR6ZtHLX4TRc28gWXNDXNpXaUZwXaTSbiBpmjfrsxRVYlXSCKVC55HkxH9bMVUQWNDFPHDTqniu3RbosbFcs+EL6WR49hElzcVfKP9t9uVU1TtC8pl8hziBZsOdPBzAl+Baiy1jdEUsEe2mez1dixuODXKC4pOdgXlrmteNP7ka6QNim9X2Te9rCuDEIiCpaHc65VnwDq3EyGK8RZcx0lJtKVWJGWSAYyhHpbBk/SwjsYNXUcMRO18Do49PagNaBfwAapR8vIZHx2lvKIxYTqV+Q2puuN+akZfpmS2xzMXlPFI4Lq1LCtXpG3JoykKhmopJ2BuCF/4rqQud2dihtyAsIC7o46HP3BzBdi7OBdPYEqoyd19yUIUFwpVt24aqSbrAOtKtvLjlYklO5qmWec+s576ZKz296xtiGzP3J0XauvBaFxTNailESscgJZ0pElhhjmOPdle9xDj7pzzKnvkfozw/SRCPYVTUumDk7hbfOGztFASs1IIRA8EAvJOHj3wm8FkCBih0KM7BijjYKp6wO4etRKmuyTFdcJ0Qkj6HFELBbw4wX56JJPrvEDbYl8/O2TOQjNjrA8VuhkygpduLWzRujirohHLjy0CHJy250Zm1rBmGw2BhKbiHjTLMNdfXLcXnf7md0wKaxSfbmYVD3c2DnxXZccj/c0akEyzjJcjJhGTeBadPn5RghdUp5bU7uXAXdLTWzmkQiSgeR0yYjIyds3vxMVScZyBN07Ih9qmdFo5CBGTdUd5zE5fVOnZkLOerzq3MXUG4pS2kS98ybuvQpWLraE3aqQJ3xhGEgSXIFw/RSR8MgDPjPJkCp0nx3aIRzHhwjJ2HX/RdkuJRXLmtKkBK0O/iH/pgAWNn5Gotp6nxk+wSrDsCBKZMyk0HJGIsYoGsuvXzGq4cOUfDz0QVnzo59tF6QsapMUEW88ar1hVyxHhZhjt/T/x0vdVxrP4K111OwBhCsiQJDa9xVdo1Yn9x+qNCvQFVRViC/v96G/D8zQgwTuZIYE6LbcOLbG/aHFP0KLn3x5i68mxbnXd5L/n45yv+7c+danyfk93W12tjJLlLFiNH20hKbDfskE8tz+CeS5jzqCrK3D2/6/LTcH5+6DLr3gUunv6dqPNHn9e0bvufuZ09foeMPEHib240/s8TCxh4n9c05s/2ec2MOaMqwpe2vK+GuuKUbHH1abYbV5/NVmMqw239Rq4z/eajNsSf/bljR+0OycwOkfaGF42Go4/rEuPayGw2q4txpOvrfV0OiMh3VyWCcfd52sv9fS/RZDC27/xVp9K2dHyCIdCckwYyM2itRV4CAJVZs5rnnZLqxV85kzvUJl2ktHpZQ2xA2FTQJsooG06DOySqDQVrpdJrIy1bxI23Yh1ehgdp4gqMaaCS7WG8tyyyJz6PmT/KmDmOhvyT+6MAXYuPc3hr3swQ==
    -s minimalExtrusionBeforeRetraction=20 -s retractionMinimalDistance=1500 -s objectSink=0 -s retractionAmount=4500 -s skinSpeed=50 -s skirtLineCount=20 -s startCode=M109 S210.000000
    ;Sliced at: Sun 22-03-2015 04:56:22
    ;Basic settings: Layer height: 0.1 Walls: 1.2 Fill: 100
    ;Print time: #P_TIME#
    ;Filament used: #F_AMNT#m #F_WGHT#g
    ;Filament cost: #F_COST#
    ;M190 S70 ;Uncomment to add your own bed temperature line
    ;M109 S210 ;Uncomment to add your own temperature line
    G21 ;metric values
    M82 ;set extruder to absolute mode
    M107 ;start with the fan off
    G28 Z0 ;move Z to min endstops
    G1 Z15.0 F9000 ;move the platform down 15mm
    G1 F200 E3 ;extrude 3mm of feed stock
    G92 E0 ;zero the extruded length again
    G1 F9000
    ;Put printing message on LCD screen
    M117 Printing...
    -s skirtDistance=0 -s extruderOffset[2].Y=0 -s extruderOffset[2].X=0 -s printSpeed=50 -s fixHorrible=1 -s layer0extrusionWidth=400 -s moveSpeed=150 -s supportLineDistance=2666 -s retractionAmountExtruderSwitch=16500 -s sparseInfillLineDistance=399 -s insetCount=3 -s downSkinCount=10000 -s multiVolumeOverlap=150 -g 49674 -s posx=141227 -s posy=36853 $
    Cura_SteamEngine version 15.02.1
    Copyright © 2014 David Braam
    This program is free software: you can redistribute it and/or modify
    it under the terms of the GNU Affero General Public License as published by
    the Free Software Foundation, either version 3 of the License, or
    (at your option) any later version.
    This program is distributed in the hope that it will be useful,
    but WITHOUT ANY WARRANTY; without even the implied warranty of
    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
    GNU Affero General Public License for more details.
    You should have received a copy of the GNU Affero General Public License
    along with this program. If not, see <http://www.gnu.org/licenses/>.'>http://www.gnu.org/licenses/>.
    Default config 'default.cfg' not used
    Reading mesh from socket with 2616 vertexes
    Loaded from disk in 0.000s
    Analyzing and optimizing model...
    Face counts: 872 -> 848 97.2%
    Vertex counts: 2616 -> 426 16.3%
    Size: 56.755000 10.117000 3.450000
    vMin: 112.850000 31.794000 0.000000
    vMax: 169.605000 41.911000 3.450000
    vMin: 10.350000 -70.704000 0.000000
    vMax: 67.105000 -60.587000 3.450000
    Matrix: 1.000000 0.000000 0.000000
    Matrix: 0.000000 1.000000 0.000000
    Matrix: 0.000000 0.000000 1.000000
    Optimize model 0.015s
    Slicing model...
    Layer count: 33
    Sliced model in 0.000s
    Generating support map...
    Generating layer parts...
    Generated layer parts in 0.000s
    Generated inset in 0.078s
    Generated up/down skin in 0.032s
    Wrote layers in 0.08s.
    Total time elapsed 0.20s.
    -s retractionSpeed=40 -s filamentFlow=100 -s infillOverlap=15 -s inset0Speed=50 -s coolHeadLift=0 -s extrusionWidth=399 -s upSkinCount=10000 -s initialLayerSpeed=20 -s minimalLayerTime=5 -s infillSpeed=50 -s supportExtruder=-1 -s fanSpeedMax=100 -s supportType=1 -s enableCombing=1 -s fanSpeedMin=100 -s supportZDistance=150 -s supportEverywhere=0 -s filamentDiameter=2850 -s initialLayerThickness=300 -s supportAngle=-1 -s fanFullOnLayerNr=2 -s extruderOffset[1].X=0 -s extruderOffset[1].Y=21600 -s layerThickness=100 -s endCode=;End GCode
    M84 ;steppers off
    ;CURA_PROFILE_STRING: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
    ;Sliced at: Mon 23-03-2015 01:44:22
    G21 ;metric values
    G1 F9000
    M117 Printing...
    -s skirtDistance=0 -s extruderOffset[2].Y=0 -s extruderOffset[2].X=0 -s printSpeed=50 -s fixHorrible=1 -s layer0extrusionWidth=400 -s moveSpeed=150 -s supportLineDistance=2666 -s retractionAmountExtruderSwitch=16500 -s sparseInfillLineDistance=399 -s insetCount=3 -s downSkinCount=10000 -s multiVolumeOverlap=150 -g 49674 -s posx=142555 -s posy=36398 $
    Reading mesh from socket with 1296 vertexes
    Face counts: 432 -> 432 100.0%
    Vertex counts: 1296 -> 216 16.7%
    Size: 14.059000 14.059000 15.000000
    vMin: 135.526000 29.368000 0.000000
    vMax: 149.585000 43.427000 15.000000
    vMin: 33.025000 -73.131000 0.000000
    vMax: 47.084000 -59.072000 15.000000
    Optimize model 0.000s
    Slicing model...
    Layer count: 148
    Sliced model in 0.078s
    Generated layer parts in 0.015s
    Generated inset in 0.407s
    Generated up/down skin in 0.234s
    Wrote layers in 0.20s.
    Total time elapsed 0.94s.
    Today I have had to shuffle a part around the build plate six times before Cura would finally output complete code. I am at a total loss what causes this. Different versions of Cura display the same behaviour.
    Any ideas?
    Currently I am attempting to print something that covers most of the build plate. Due to this error, getting a proper G-code output is proving to be impossible.
    I can hardly imagine being the only one with this problem. I uninstalled all Cura versions and reinstalled the latest version, tried saving to different locations and a couple of other tricks, but the problem persists. This is really interfering with day to day printing.
    Can anyone see anything in the logs? Does anyone have any other suggestions on what to try? Am I overlooking something basic?
    I don't see anything weird in the logs. This is very strange...
    Just to add some points to this not being an isolated case.
    I had this happen to me today with cura 15.04
    While writing 5mb gcode, cura stopped after 4.5mb, and not at a layer change or even a line change.
    Didnt realise it till the printer was 10hours in, so had to do some emergency surgery to finish the print by slicing the file again, and removing the already printed gcode.
