Raised Edges - Simple Metal
artpen
Posted · Raised Edges - Simple Metal
Hi guys,
I have started to use Cura and all my prints are almost perfect except one problem.
I have found same issue on this forum but couldn't fix it on my Printrbot Simple metal
I basically have raised edges, it looks like over extruded, but I have reduced filament flow and still have the problem.
But what interesting if I print a cube it happens only on two corners . please see image.
Thanks for your advice.
    I'm sorry, but from the image it looks to me like the z-seam?
    In that case there's not much you can do with Cura, I'm afraid...
    Thank for your guys.
    Yes, I have tried to print more then one cube, with and without brim.
    Both cubes have the same issue and only from one side!
    I have tried to rotate them the issue still from the same side.
    It looks like it is a point where hot end stops and starts to print next layer.
    What does Z- seam means and how to fix it?
    Cheers
    From the post,It looks like there is no solution :(
    Any other ideas.
    I will try to print a simple cylinder just to see if it is a Z_scar
    Ok...
    I have just printed some tests.
    Settings are the same
    1. Two cubes with option print all at once. And they are perfect!!!
    2. Just a single cylinder. It has two seams
    3. One cube - seams on two corners again
    There should be a solution, I can't print all parts two times ))
    Just a thought maybe it it because of Z-Hop. Mine is 0.075
    Hmmm... that's maybe a value the printer is not comfortable with. Try 0.1mm as this is the z resolution of the Simple Metal, isn't it?
    What print speed do you use? A lower print speed might smooth the effect as it doesn't have to slow down that much for the z step... Can you reduce the temperature a bit without getting underextrusion or are you already at the lower limit?
    Hi there,
    Yep i will try with 0.1. Thanks for suggesting this.
    I am printing at 195 -197C and my printing speed is 50.
    I can try to lower the speed to 30 and temperature to 190C - just to test.
    Will come back with resultsrobably tomorrow
    Have you got one or two extruders? I ask because I can suffer from this on the cube too and I have two extruders, which pushes the right hand fan further away; this makes me think the right hand side is not cooled enough. I am thinking that your success with printing two pieces might support that view.
    Nope, I do have only one extruder
    Ah maybe wrong question :cool:. Are the fans equidistant from your extruder or is there a space to the right of your extruder to fit a 2nd extruder? That would cause the issue I was referring to.
