Hmm... that's very interesting... I can see in the layer view that the extruder is traveling from the outside of the left leg to the outside of the right leg...
I'm running the latest - 15.02.1
The print looks very clean and I don't see any bulges on the leg that keeps getting hit. Do you have any ideas how I might be able to fix that behavior?
Thanks!
pm_dude 27
What version of Cura are you using? If you are using Cura...
Since version 14.12 I noticed it changed some behavior in the way it starts the new layer. This causes the Z step to occur during a long traveling from end of layer A toward beginning of layer B. In previous versions the layer B would start very close to where the layer A ended.
This could be the cause of the leg getting knocked out.
