Wow...really nice! By the way my most important problem is i can't print anything before the "fuel tube addon"...this mean that, unfortunately, can't print the owen's fix or everithing else can help me (it fails every time for some reason, also with simple 50mm cube as you can see)...
AND I CAN WATCH TV ON SOFA WHILE PRINTING
Isn't that a great feeling? I had similar problems too, once you can print problem free its bliss.
When I cut my tube too short I just moved the x and y end stops until I got a replacement tube.
It cut about 5 cm off both dimensions, but I didn't find it limiting as I rarely print anything that fills the bed.
Watching TV while printing is fantastic!
Yes, i can print little object if place it in centre of bed but i need to print somenthing larger (the reason why i had bought the Ultimaker is to print this thing)...by the way every print before fuel tube fail after max 20/30 mins (with a jamming of grinding)...with fuel tube i am printing for about 2 days (still printing now) without adjustement of screws and without jamming/grinding! I don't know if heir elasticity resolve something but seems like it absorbe the excess of filament quantity/pression and regolate the pushing into the nozzle (the objects is really more regular now!)...
is this some sort of silicone tubing? my fuel tube here is black, with thick walls and not at all suitable i think. you don't mean fuel tube from a car do you?
it's a commonn fuel tube (i think whatever tube enough elastic can do the job); i have obtained it when i changed the old on my motorbike...i don't know if can help but i can see writed on it "Akron benz 5x9"...
Looking at it I would guess that it is likely the sort of hose you would find on a lawn mower or around cool areas - some sort of PVC hose.
The black stuff you're talking about is probably a synthetic rubber hose, depending on the reinforcement may be used for the injector rails where there is more heat and pressure.
I received the new bowden from Ultimaker, mounted it and nothing works again (also tried a new nozzle to be sure the problem isn't regarding it)...no more plug but A LOT of grindings (i had used about 350g of transparent PLA during weekend to try get a working Ultimaker...with absolutely no success and a mountain of half printed enclosures)...
Today, while completely desperated, i had reinstalled the "shock absorber bowden" but for my curiosity i had maked a little more change (i had used the cutted bowden piece from where i removed the plug with a Dremel..yes i know, it's a really brute force attack but i need to know):
In this way i think can obtain 3 things:
- Length of bowden can be adjusted (i can change it moving up or down into the owen's clamp)
- If the filament pushthe bowden out push out FROM the clamp and not from the insulator)
- The heat coming from the nozzle into the bowden can go out
I'm printing a big object from about 1 hour without any trouble...update coming when (and if) finished...
I don't see that this is a long term solution. The space/gap in the Bowden is just going to make slippage in the standard Bowden clamp even easier.
But there is substantially less force on the bowden section that forms the seal now in terms of the extension and retraction, it is all taken up by the PEEK/Brass part, owens clamp and the tie rods on the head.
I would be more concerned about the difficult of inserting the filaments as well as whether the filament will buckle at that point because the tubes aren't really well supported anymore.
Good point.
Any update on how it's been going?
I've not found Owen's clamp to be 100%, so it might slip over time, but this will, at most?, cause a minor flow decrease for the period of the bowden movement and nothing else.
- 1 month later...
I would +1 phut. I've been able to transition colors in the middle of prints (very cool for logo extrusions, but requires some trial and error) by snipping pieces of filament and creating "queues" of filament. If there isn't a complete pathway to the head I don't think that would be possible...
dinac 0
i made shorter thread for fixing bowden , just for all who cutted tube few times :
http://www.thingiverse.com/thing:27376
but as i see, you cut a lot, so there are no point to print this![:)](//content.invisioncic.com/ultimake/emoticons/5a33abdf6d109_1f60acopy.png)
