Thanks a lot guys.
At first i didn't want to go higher because i feared that it might get me nozzle clogs but it's worth a try.
I'll try printing at 245° or even 250°C, with 25% fans and no retractation (I'll have lots of stringing but that's not a major issue).
I have to see what i have in my house to build a nice enclosure.
I'll keep you posted later in the week for the results.
gr5 2,229
240C is too cold if you want good layer bonding. I've printed ABS and it had "okay" layer bonding but compared to PLA it was weak. I'm not sure what the correct temp is but 240 or 245C is definitely on the cold end and you can get these layer separation issues.
Fan at 25% should be okay but I recommend with ABS that you put a box over the top and cover the front with clear plastic to get it up to about 60C inside (don't go much hotter than that because the steppers get too hot).
A photocopy paper box is the perfect size to put on top of the printer with room for the bowden:
tsagos 8
+1 for gr5
Higher temp
lower fan speed
enclosure
( still not enought for me though :( )
tip: when you are printing above 240 try, if possible, to print without retractions. Hot fillament will wear teflon piece faster.
