Thanks for responding. I have had a play with those setting with little success. While changing the X/Y distance to a large value like 5mm does seem to force the support back such that the hair is supported, that of course removes the support for other parts of the print, such as the skirt. It seems to just move the issue around. As for selecting the touching build plate option that removes a large amount of the support that is needed but it does not add any.
stu_le_brew 42
welcome to the forum
I would try using "touching buildplate" rather than "Everywhere" for support type
Also there are other parameters you can change if you select the box (with dots in) next to the support type button, apologies if you have already tried this
