Go for it. The worst that happens you break a pololu and they are cheap to replace.
well actually the SilentStepSticks are rather expensive
However, you should just go ahead... I also got really tired of the sucky std. fan and replaced the cover with a printed one that holds 2 x 50 mm. fans from fractal design... It works a treat, and along with the sss drivers makes the printer super silent... that is, until my new cross flow fan kicks in an sends the printer flying
Edited by GuestNeatherbot desined a good version, which I also put onto my UMO.
Thanks for the feedback. Will give it a try when I get the time to do it. The TMC2100 chip on the SilentStepSticks fortunately has a overtemperature detection so they should turn off before being cooked. Not sure if there are other hotspots on the PCB (besides the voltage regulator)?
- 1 year later...
It only took 1½ year but I finally replaced the fan, power supply and added a heated bed (JasonK mk 2) to my UMO. The frame is a slightly modified version of the template from formfabrik. The fan is an old 12V Papst 4412 FGL 120 mm fan (55 CFM so plenty of air). The power supply is a 24 V 15 A Chinese no-name PSU adjusted down to 21.1 V. I intent to replace it with a Mean Well SP-480-24 PSU (20A). I used a 5A step down buck module to replace the 12 V regulator and feed the fan. I used the ARD PWR jumper to bypass the 7812 regulator. .
TheGuyKnownAsDim3nsioneer 11
Please make a video when your UMO starts to hover...![;)](//content.invisioncic.com/ultimake/emoticons/5a33abe00be82_1f609copy.png)
Seriously: Be careful and make sure that the parts which need cooling get it. Usually a lateral flow is better for cooling than a frontal flow.
