All Activity
- Past hour
AlexMacMini joined the community
- Today
Slashee_the_Cow started following Cura software and Raise 3D Pro Plus
I'd just like to pop in here and say that unless you're using specialty high speed PLA, you shouldn't be printing this fast. A lot of spools of filament will list on the side the recommended speed. For regular PLA, it's usually around 50-70mm/s (I go at 60, unless I'm doing something with fine details). By default the "print speed" setting in Cura will do the infill at that speed (not so bad if it doesn't quite print right since it should be invisible to the outside, assuming you have enough walls and shell layers) and everything else at half that (if you ask me, it should do everything at the print speed entered, except make the infill twice that or whatever).
Cura 5.6 and 5.7 refuse to slice basic cube.
Slashee_the_Cow replied to zBeeble's topic in UltiMaker Cura
This is why you rename the config directory instead of delete it. All your settings are still going to be around and if nothing in there is a problem, sure you have bigger problems, but you can just rename it back and everything will be just like it was. And doing it this way if something in there is a problem, you'll have everything except that. -
Event_Horizon5 joined the community
- Yesterday
kaninchen55 joined the community
CorgiBearlord joined the community
Wow! That's amazing.. Beautiful prints What kind of printer do you have?
There were 6 pauses in these drink coasters. 8 pauses in these shark fins. 6 color changes, two nuts inserted, and a 3/16" x 9" steel support rod (you can see it running at an angle). The front portion is glued to the rear and the angle brackets connecting to the roof rack ties everything together. The PETG has held up really well in the Florida sun (and on the roof of a car!!). They've been on there for about a year. I made regular shark fins out of gray PETG. I want to do a Pirate motif with LED brake lights in the rear. The PETG holds up, but I don't think I'd trust it in black. Maybe with more steel reinforcement.
christopherv joined the community
If the speeds are within your Printer Definition file as formulas (like "inner-wall speed = Print Speed / 3") then you will get them jumping around as they re-calculate. If you over-ride a speed by simply entering a value, then it becomes disconnected from the "parent" setting. To re-connect a "child" you would use the "fx" icon next to the setting. Yes, M203 is max speed for each axis and doesn't care if it is an outer-wall, inner-wall, whatever. They are dependent on each other though. If the speed of an extrusion is faster than the E parameter in M203, then the speed of the XY would be limited because the Extruder would not be allowed to keep up. That doesn't happen often, but nozzle size can affect it because the flow rate is affected. "A lot of science goes on in the little space below the nozzle." - Me If you open a gcode file in a text editor (like Windows Notepad) you will see "F" values in the lines. That's the feed rate and is in mm/minute. Divide them by 60 to convert to mm/sec. They should mostly match up with your settings in Cura.
4ejlv joined the community
fernandomema joined the community
Sorry if it feels like I'm pestering you, I do appreciate your help, and in part I am venting my frustrations. I'm running a long print so it will be a little bit before I can test this, but I was dealing with prints taking about 1.4 times as long as predicted, so that's why I'm so concerned about how slow its going, Id rather my 24 long prints not take 34 hours. I don't have that setup at the moment but I will look into it. However, I am fairly confident that I have met or exceeded the values I am asking it to do on gcode coming out of ideamaker. I will test your Start Gcode when I get the chance. Is it ok for me to not define the M203 Z and E, since those haven't seemingly been problems yet I don't want to mess anything up. If it was purely just a problem of not being able to exceed a certain speed, wouldn't both the inner and outer walls be going at the same maxed out speed? Instead the sequence each layer is - 2 inner walls seemingly at 50 mm/s - 1 outer wall seemingly at 100 mm/s - the first straight line of (gyroid) infill will be at speed, 100 mm/s - then the rest of the infill will be at a slower speed, presumably back around 50mm/s And this is all in spite of the Gcode to the best of my parsing all showing the correct values. Its almost like the machine is trying to read the speed values from somewhere else. Its just observational but it seems to be using a slightly wrong version of the Cura calculated speeds, in that it appears to be doing the two wall speeds as multiples of each other, albeit in a wrong order, and seemingly independent of the value I set as overall print speed, instead sticking to the default 100 mm/s.
EzeySil joined the community
ugh. So much memory is in the config. I'm always so frightened to move on --- that I'll never get back to where I am ... or will chase little errors. But the obvious solution is to try this first on my workstation ... and not the workshop laptop. And I agree, it's a good thing and the right direction. I just want you to know that it's _very_ scary!
The printer knows what it's maximums are for the feedrate and acceleration on each axis. If you have Printerface installed and a USB connection to the printer, you can send M503 and the printer should respond with it's settings. This is my printer response: You can put that M203 line anywhere within the StartUp Gcode. I would suggest you do it like this: M201 X1000 Y1000 M203 X250 Y250 Z45 E50 and see how it goes. That M201 line will set the Max X and Y accel to 1000 and the M203 will set the Max feedrates for each motor.
Thanks a bunch this is great!!!
alcnfred joined the community
I looked at the formulas and they already consider the nozzle size. If the "reload" amount is too long then the filament will get to the nozzle before the speed slows to "purge speed". As written, the script reloads 90% of the "reload amount" at max E speed, and then slows to Purge Speed (3.33mm/sec for a 0.4 nozzle) for the last 10% of the reload amount and for the Purge Amount. So it sounds like your "reload" amount is too much. Probably the Unload Amount as well. The extruder should quit retracting just when the filament comes free.
josiahschickens joined the community
I agree with not changing too much while its working. The weird part for me is still that when reading the gcode in other softwares it shows the speeds I want. It just doesn't do so on the printer. I can try adding in your M221 and M220 commands, but another thing I saw I could add is an M203 command, something like this, and if so where in the startup Gcode should I place it. M203 E? X130 Y130 Would this be a reasonable explanation for how the Gcode seems to be correct, but the machine doesn't want to follow the specified speeds? This still wouldn't address the fact that its also doing slower speeds for the inner walls and then faster speeds for the outer walls, but if it was at least listening to my speeds, I could just put the numbers in backwards and let it mirror them so it would be correct. Another thing I realized is the printer profile I built is adapted off the N2 Plus which may have had lower limits that are somehow affecting this.
The Unload and Reload numbers need to be adjusted to your machine. The purge number needs to be adjusted to the filament. For example if you are changing from white to red it will need to purge more than going from dark blue to black. I didn't add the purge speed because I didn't deem it necessary. Purge speed is hard coded to 200mm/min or 3.33mm/sec. I can see where that would be too fast for some machines. I think I'll add a formula based on the nozzle size and a print speed of 75mm/sec. I'll post it when it's done.
GregValiant - It worked perfectly - will try again.. only issue was maybe too much filament comes out on the purge - Maybe a tad slower on the purge and not so much.. Going to give it a go again - apparently you have back out and on the touch screen and then play button resumes. Finally got the play button back with this new script.. this is great thanks. Oh and had to change pause command to M25BQ - this is what brought the play button back. With the default settings it doesn't. Not sure if these are ideal with the purge amount #s, so any other numbers which you think might be ideal could work too. Thanks..
gr5 started following First Layer Doesn't Stick Properly
The first layer looks a little underextruded and you really want to squish hard to get things to stick. How hard the first layer squishes is the most important thing by far but not the only thing. some (not all) of the other things are removing surface oils (that come from your fingers probably), glue, brim, bed temp. squish 1) This is a UM3 right (I don't think you answered slashee's question)? 2) Do you use active leveling (I don't on my UM3)? Assuming you do manual leveling, turn the 3 bed screws CCW as seen from the bottom to move your bed up just a tiny bit. Turn them all the same amount, about 1/2 turn. This should increase squish without changing the "level" part of leveling. material Is this PLA? I don't think you mention anywhere. This is crucial information. glue 3) Did you use hairspray recently? I don't like hairspray much because it can get all over the printer and cause havok with all the moving parts. bed temp 4) Do you have one of those contactless IR thermometers ($7 at harbor freight)? I recommend you get one. Check the bed temp with that by pointing straight down (any kind of angle will reflect and you'll get the wrong temp). It should be 60C. Your temp sensor on the bed may report 60C when the bed is actually only 30C. Please respond to all 4 questions!
Tip, from experience: edit your earlier post to remove the attached file. And consider giving them version numbers so if someone has a problem that's already been fixed... you get the idea.
And this is the sort of thing that happens when I scramble late at night. The new "enable" box had a bug. This one doesn't have that particular bug. PauseAtLayer.zip
My good, old Ultimaker S5, which has been in use for almost 5 years, always on, suddenly died this night. It completed a print last night. This morning the screen was black, no light, totally dead. I checked the power button, the cable etc, but it's not something external to the printer. Since is not reacting at all to the power button, I guess a fuse has blown. Has anyone experienced the same? Any tips on what it could be? Marius
Well you can approach this from one of two directions (as literally as possible), I prefer the "scorched earth" approach myself. Go to %APPDATA% and rename the entire cura folder so it's forced to generate a completely new config from a blank slate. If you're using a custom printer definition, open Cura, then just quit it and put your definition in the %APPDATA%\cura\5.7 (definitions and variants if necessary, if you have a custom definition then you've already done this) folder it should have created so you can open it again and your printer will be in the list to add. Anyways, set up your printer. Get a model which won't slice (if you want one from the calibration shapes plugin, then go to the configuration folder you just moved out of the way and they're in plugins\CalibrationShapes\CalibrationShapes\models\) and see if it'll slice. If it doesn't, then either your custom printer definition is causing it or you have bigger problems. Then it's basically a matter of "close Cura, copy something from previous configuration folder into new one, open Cura, test". If it stops slicing after you copy something, you've found your culprit. Personally I'd test in this order: cura.cfg (overwrite the new one it made) If your printer setup differs from its definition (you've changed some of its settings in Cura) then the changes will be in a file in the definitions_changes folder, so that All the post-processing scripts (which should have nothing to do with it, but computer programs break in mysterious ways) Any custom/changed materials (just the whole materials folder), although if it's happening with a generic material it's probably not this All your quality settings profiles (they're in the quality_changes folder) and then test with those profiles Plugins. Ideally, one at a time. Yes, I know it can take a bit of time if you have a few (I have plenty). To cheat, you can do it about three at a time, just remember which three in case it breaks it you can uninstall those three and test individually. For ones you can find in the Marketplace, download them from there, if something is no longer listed there, copy it from the plugins folder in your old config folder. Then... that's about everything covered. If it works after that, you probably had a bum configuration file somewhere. And when I say you can approach it from the other direction: that's starting with what you have now and removing things individually until it works. But I prefer to do it from the ground up in case of things like aforementioned bum configuration file somewhere which you wouldn't get around to removing. -
That's brill @GregValiant I'll check out the new version & thanks for your continued plugin work
PrusaSlicer places seam in notch. Can Cura do the same?
NTwoO replied to NTwoO's topic in UltiMaker Cura
Thanks! Ill give this a try -
OK. What do I do next to diagnose this. I don't want to wall myself off from Cura updates.
No... it's obviously fine. heh.
Chosing where to print different layer heights
Slashee_the_Cow replied to Donnelly_O's topic in Improve your 3D prints
Alas, you are correct. You could try it with a file with regular supports but open the gcode file in Cura so you can see what the preview looks like before you try and print it. -
Plugin to Change a Setting at a certain Z.
In theory, it's going by layer number in the Cura preview, which starts at 1, but in the gcode the layers start at 0, so I subtract one from the value you put in the settings (because what the Cura preview says is layer 250 is labelled layer 249 in the gcode, but it is in actuality the 250th layer). I can change it if you want. Whenever I do a script for someone I always want to have a happy customer.
