Thanks for the reply. I use all the standard settings of Cura for UM2. So cooling... more or less?
See the image (i found my camera) the bigger the box (left is biggest), the more it shrinks at the bottom layers touching the plate.
Both boxes should have stayed flat on the bottom.
I will try the next one with a lower glass temperature. Or switch the glass temp off and use a sticky spray.
Dim3nsioneer 559
What do you mean by 'corners are shrinking'? Are the edges not as sharp as on layers below anymore (increased edge radius)?
The bed heating might have an influence but usually it can be cured by correct fan settings. Make sure you have the right amount of cooling. Switching off the heated be is a bad idea as your print will then soon come off the bed. But adjust the bed heating to something like 60 or 55 °C if you're still higher. I read about people going down almost to 40°C during the print.
You can adjust the bed temperature in the 'tune' menu during print or you can use the TweakAtZ plugin if you want to reduce it at a certain height/layer no.
