Posted · Cura 15.04 not available
to buy it.
uhm whut :p?
Freudian slip.... ;)
    err derp derp. Download it. Damnit. You dont need to buy it.
    Hi @Titus,
    There's a certain download limit to prevent spam downloads, but I guess the limit was a bit too strict. We're changing it to max 3 downloads every 15 minutes for every user (based on IP).
    This link: https://software.ultimaker.com/current/Cura_15.04.exe that you posted gives me a 404 error.
    The Linux link: http://software.ultimaker.com/current/cura_15.04-debian_i386.deb doesn't work either.
    Just go to software.ultimaker.com. Everything is there - new and old versions.
    Having the same problem, and tried multiple links. Same result : 404 Not Found...
    The above link works fine for me. It takes me to here:
    https://ultimaker.com/en/products/cura-software
    Then there is a link to older versions:
    https://ultimaker.com/en/cura-software/list
    The links work, but after proving you are not a robot, the download link leads to a 404.
    Posted (edited) · Cura 15.04 not available
    Works fine for me in Chrome.  Try a different browser.  I "proved" I'm not a robot and then it just started downloading.  Must be some javascript thing that is blocked in some browsers maybe. Both for an older version and for the current version of Cura.
    I'm using Chrome. I can download 15.02.1, 15.06.01, 15.06.02 but not 15.04 (for both Windows and Mac). I don't need to. I was only checking for others.
    ..same with Firefox.
    It works just fine for me. Don't use the direct links, use this list: https://ultimaker.com/en/cura-software/list
    It works now for 15.04 on both Windows and Mac. It definitely didn't over the weekend.
    We do fix things when people mention it ;)
